x-post: 951 garage sale
Thefu
Huge garage sale listed in the FS forum: https://rennlist.com/forums/for-sale...tems-also.html
PM for details or requests. This stuff needs to go.
edit: Calling dibs on parts is fine if you are honestly going to purchase, but please do it in the thread in the FS forum to avoid any complications.
Thefu
For those that may be click challenged:
Late Spring Clean-up. I need room so this stuff needs to go.
All items are OBO. I have NOT researched prices on these items, yet I am compelled to list a price by the rules. If you find a price to be too high, let me know (with a link if possible) and I will correct to reflect current used market value. Items for racing only, or racer interest are in red.
If you have a specific question about an item, or need a close-up photo to verify fitment, use, etc, please PM me with requests. All items are ready to be bolted up and used immediately except where noted.
Front turn signal assy, 951 (1 set) $25
Front side marker assy, 951 (1 set) $15
Rear side marker assy, 951 (1 set) $15
Wiper motor assy, all 944 (?) (1) $50
Oil pump, 951 (1) $50
Throttle body (1) $50
Camber plates, racers edge (1) NIB $200
Clutch release bearing, 951 (1) NIB $25
Shifter handle with rubber boot (1) $10
Fuel rails, 951 (2) $15
Intercoolers (2) $50
Starter motor, 951 (1) $50
Distributor cap assy, 951 (2) $25
Oil filter housing, 951 (1) $25
K26/6 turbo, with downpipe (1) no play $100
Cruise control motor (1) $50
Engine crossbar, 951 (1) $50
Transaxle crossbar, 951 (1) $25
Lower radiator shroud, 951 (1) $25
Intercooler shroud (1) $25
TiAL blow off valve, (1) NIB $100
Alternator, 951 (1) $75
Radiator w/ fans, 951 (1) $125
Coolant expansion tank, 951 (1) $25
Turbo coolant pump (1) $25
Bell housing, 951 (1) $25
Brake cooling ducts, 951 (1) $75
Window net (1) $25
5# halon w/ remote pull (1) $125*
Carbon fiber rear bumper (1) $100*
100x4 amp (1) $25
70x2 amp (1) $25
Cam tower, 951 (1) $100
Torque tube, 951 (1) $150
M030 30mm fr, 19mm rr sways (1 set) $200*
Head, 951 (1) $500*
Rear banana arms, 951 (1 set) $150
Water pump, 951 (1) rebuilt $75
Dial-in cam gear (1) $75
Valve spring installation tool, Snap-On $75
Injectors, 951 (1 set) $50*
Tilton pedal assy (1) $50
Oil pan, 951 $50
Additionally, I have some other engine parts laying around including heat shields, turbo intake tubing, j-boots, etc. If you have a need, PM to see if I have a part for you.
I also have a complete set of Koni double adjustable dampers, front and rear. Rears have factory helper springs, fronts have factory springs with adjustable perches. This set can be adjusted for compression and rebound on the car, no need to remover rears and compress to adjust. All have been rebuilt by Koni NA. PM for details if interested.
All prices are again OBO, plus shipping from 33556. Paypal works best. Would rather not ship overseas, but if an overseas member has an interest in a part that does not have CONUS interest I will consider shipping.
Caveats:
• Halon extinguisher will need new tubing fabricated. I have 2 nozzles and fittings.
• Carbon fiber bumper has a 1cm chip in the “gelcoat”.
• M030 19mm rear bar is missing 1 bolt that connects drop link to arm.
• Head has some corrosion on the mating surface and will need to be either cut, or welded and cut to insure good sealing with head gasket. Head is otherwise rebuilt with new and/or reconditioned valves and valve springs.
• Injectors are in as-off car condition and probably should be reconditioned.
Window net (1) $25
100x4 amp (1) $25
70x2 amp (1) $25
Head, 951 (1) $500*
Oil pan, 951 $50
Caveats:
Thefu
If you could please post dibs in the FS forum. If we have dibs here and there it's going to get ugly soon and I'd really like to avoid that if at all possible. Thanks!
If you simply have a question, I'd be more than happy to respond here.
Thefu
Only memebers are allowed in that forum (which is why I posted here as well).
Your PM has been replied to, thank you. I'll let you know if the previous people that showed interest do not follow through.
Thefu
turbopower:
Sorry, but that was claimed almost immediately (as a user you can't see the thred in the FS forum which has the sold staus on it.
Here is the current list of available items:
100x4 amp (1) $25
70x2 amp (1) $25
Head, 951 (1) $500*
Oil pan, 951 $50
Spindles and hubs, non-M030 (2 sets) $100
3 bar adjustable fuel psi regulator (1) $50
"Cup" exhaust, cat back, straight pipe (1) $150
Door lock solenoids (1 set) $15
HKS EVC IV boost controller $250
I also have quite a few misc bits floating around like clutch master and slave cyl, engine heat shields, tensioner, etc. If you need a part for an engine rebuild or other project, PM me with your request.
100x4 amp (1) $25
70x2 amp (1) $25
Head, 951 (1) $500*
Oil pan, 951 $50
