CPRacing V1 splitter mounting question. (Pic request)
Old 04-28-2009, 07:06 PM
Chads996
Chads996's Avatar
Default CPRacing V1 splitter mounting question. (Pic request)
Can someone provide me some photos of an installed V1 splitter? I have some fitment problems and I need some references from a installed splitter.
Please show specifically:
- Underside if possible
- Mounting to wheel well liners
TIA.
C.
Old 04-28-2009, 07:09 PM
951Porschiste
951Porschiste's Avatar
Will this help? Soory no pics of the underside...
Old 04-28-2009, 07:47 PM
Chads996
Chads996's Avatar
Thank you. Can you take a shot or looking into the wheel well? Specifically where the back portion of the splitter mounts to the bottom?
C.
Old 04-28-2009, 07:53 PM
951Porschiste
C.
Car is at home and I won't get back until late tonite
Best I have right now is the following.
Old 04-28-2009, 07:57 PM
Chads996
Chads996's Avatar
Thank you! Maybe mine is correct. Hmm... Have to do some checking at the shop. THANKS!!
C.
Old 04-28-2009, 08:48 PM
JohnKoaWood
JohnKoaWood's Avatar
Just make sure to turn the wheel to the extremes, I have monoball bushings, and all new suspension otherwise, might have had something to do with mine, but I needed to trim approx 1/2 inch off the back edge in the wheel well to clear the tire at full left an right, had some rubbing at SLOW speeds (parking lots and such)... Jigsaw cut right through... if you don't like the protrusion into the wheel well..trim it to suit you...
Old 04-29-2009, 08:18 AM
951Porschiste
Chad,
Here are two more pictures which I'd forgotten about. Hope it helps...
Old 04-29-2009, 09:44 AM
CurtP
CurtP's Avatar
I didn't remember to take any pictures, but I didn't use the self-tapping screws near the wheel wells. I did drill two holes on each side and screwed up into the brackets for the fender well liner. The picture above looks like it only has one.
Quick Reply: CPRacing V1 splitter mounting question. (Pic request)
