55psi on stock injectors and fuel pump = ok?
Am I safe?
Previous owner of car did set 55psi (Lidsey AFPR) - (fuel rail gauge 50psi at idle 55psi ar rpm's) on stock injectors and fuel pump as well as rised turbo to 16psi.
I am so sorry if I'm asking a dumb questions......
That's almost 4 bar fuel pressure plus 1 bar from the boost pressure. That will put extra stress on the injectors and the DME computer; very possible that you will break them. Also, the fuel pump will have only a little better than 50% capacity to put fuel into the engine, which may or may not matter.
I've run 60psi at the fuel rail for 4+ years. The big question isn't if the injectors or fuel pump are OK but are the chips in the car giving the right mixtures with that fuel pressure. You need a wide band to know if the mixture is good.
Basic Sponsor
That's no problem for a Bosch injector.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
No, I do not have a wideband, just a narrow one, which shows i'm running a little rich. He told me that he rised a little of lb via mapping chips, but i'm not sure what does it means?
Do I understand correcly? By chip you are adjusting injector duty cycle to optimise air/fuel ratio?
to up the capacity of the injector output
I have ran at higher pressure on E85 for some time.
I just had an injector fail but it most likely due to me running them at 100% DC and not pressure.
