Q's about rebuilding power steering rack.
Just a few quick questions.
Is this the kit I need to buy to reseal the rack on a 951? http://www.rennbay.com/rack-944-powe...d9c2b0f591d792
Is rennbay the best place to get this kit or are there other places which will be cheaper? I'm getting two, one for each car because both need it.
TIA guys!
TIA guys!
TIA guys!
TIA guys!
Thanks John! I figured that was the right one, just wanted to make sure. I'm going home this weekend for easter so I'm going to pull the rack on the red car, rebuild it next week, swap it into the white one, and rebuild that rack, then put it into the red one. Kind of assbackwards but since the red one is sitting til we pull the fenders out (also planning on doing that next weekend) it makes sense. I know to keep a sterile work environment and take my time and be patient. Good thing I've had 4 exams in the past 2 weeks so I won't have anything keeping me up late studying! haha
I would echo what John said. Be very careful about the parts, and keeping everything clean. It is an easy task, but also easy to go wrong. You will need a wheel alignment when done, as the tie rod ends can never be fitted accurately.
Philip
Philip
Oh, and a hardened steel scribe (one end straight, one end 90 degree from straight) will come in handy, as will a hooked one, but the hooked one is not required...
I also did my PS pump at the same time, pump I would rate about a 2 on a scale of 1 to 10, Rack I would rate an 8 simply because of the number of pieces you will spend time figuring out where they are (like the last couple of scraper seals (one is in the bottom of the valve body on the rack, the other is in the sleeve you will remove... you WILL know what I am talking about when you take it apart)) just be patient.. and if you need a different tool, and can't find it in your box... wait and go out and get it, trust me, DO NOT go through the trouble of taking it apart to not take your time and put it back together correctly... all in all it is really a very simple job to do, the seals and their locations make it a pain...
I used a dental pick, and needle nose vise grips. Just be careful not to score anything, when your in there. I remember one seal IIRC it was where the pinion meets the rack. Youll see it, and it will click(youll know what im talking about) when your in there, be careful with that one, its a pain. The rest were easy IIRC. The rack I did im still using over a year now. Not many miles tho.
