Help! off throttle rpm dips below 700 shudders or stalls*SOLVED*
**********SOLVED**************
STEALTH MAF SENSOR ORIENTATION *FAIL*
Coming off throttle car shudders and then comes back to normal idle or on occasion just stalls
With help from vitesse*John and The DareDevil*Derek we have not been able to solve it
zt-2 data capture of the event *attached*
Check list so far with ought a cure:
- Make sure the TPS is giving the IDLE signal - NOT YET
- Make sure your Idle control valve is clean and functioning - DONE
- Of course, double check for vacuum leaks. - DONE
- Reset Idle via Idle Screw on the TB as described in the owner's manual (or clark's garage). - DONE
piggyback-Global Settings ===> Analog ===> Min Fuel" - DONE
PENDING - Check the IDLE switch, make sure it's giving the IDLE signal. Check this at the DME/KLR
PENDING - Eliminate one possibility. Use the shorting plug in place of the PiggyBacK
How did you adjust the idle? You're supposed to disable the ISV on a warm engine and bypass the ISV by jumpering pins B and C in the diagnostic socket to set the idle properly.
Basic Sponsor
Try setting the throttle body idle properly including hard stop. Run the factory 02 sensor.
Un-plug the vacuum hose to the bypass valve (cap hose off) and see if it makes a difference in how often
it dies. If it does, get a stiffer spring so the bypass valve is closed other then coming off boost.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Basic Sponsor
When you turn on the key, and the engine is not running, put your fingers on the
idle stabalizer and see if you can feel it vibrating. If not bad TPS, Stabablizer or DME.
if the stabilizer didn't work it would just stall instead of bounce back - vibrating way
DME - possibly but no other problems
Eliminate one possibility. Use the shorting plug in place of the PiggyBack. Also measure the MAF voltage at the DME #7 and compare it to the voltage on the MAF itself. If the voltage is different, the wiring needs some cleaning up.
We went through this last year when you had the lose wire. You should have the emails!
Check the IDLE switch, make sure it's giving the IDLE signal. Check this at the DME/KLR..
I had a similar problem when returning to idle it would dip then jump back up. For me it was just resetting the idle control valve using the factory procedure jumping the wires at the testport.
long story short, I decided to play with idle screw, no longer dips while idling BUT off load it still happens.... Which was the case in previous history
Worst part was that the signal at the maf when i checked it was normal
I was heading to check voltage to MAF and found the problem.
Thanks everyone for your input much appreciated!
Installing the MAF with the wrong orientation NEVER works. Just be glad you did not cause any damage. Looking at your data log, I knew you were way off and something was wrong.
