Hood Insulation
Old 03-18-2009, 04:03 PM
schnellfahrer
schnellfahrer's Avatar
How do they ship these? Are they rolled up or something?
I need to replace mine, but shipping could be a problem, or?
Old 03-18-2009, 04:18 PM
flpaindoc
flpaindoc's Avatar
Paid $9.00 for shipping (regular US mail), FEDEX was $10.00.
Old 03-18-2009, 05:48 PM
testarossa_td
testarossa_td's Avatar
I run nude....in Texas and have not had a problem for many a year.....not to say it is not coming but so far so good.
Old 03-18-2009, 06:02 PM
purple_rado
purple_rado's Avatar
i replaced mine last summer with the weltmeister stuff from paragon and have been very happy with it.
Old 03-18-2009, 06:52 PM
V2Rocket
Rainman
V2Rocket's Avatar
never had a problem with temperatures though i do have an NA, however i have noticed that driving a (late) car with hood insulation is alot quieter than driving my early without it.
Old 03-18-2009, 07:23 PM
Luis de Prat
Luis de Prat's Avatar
They come flat, in heavy plastic bags.
Old 03-18-2009, 08:46 PM
ELLSSUU
Geaux Tigers!
ELLSSUU's Avatar
I put factory OEM back on my car after it was repainted. Even though I was extremely careful cleaning off the area and intalling it is already coming off/sagging. My car never sits in the hot sun and is kept very very clean all of the time. I'll replace with the Paragon stuff the next time and that's not only because it's much much cheaper.
Hopefully you factory guys will have better luck than me.
Old 03-18-2009, 08:52 PM
CarbonRevo
CarbonRevo's Avatar
FWIW, my '91 S2 doesnt have insulation.
I tryed to get rid of all the insulation on the hood of my turbo...I finally gave up. Products will weaken the paint which will then come off. I plan to replace mine, but haven't decided if I want those bright silver ones or not.
Old 03-19-2009, 07:06 AM
Luis de Prat
I've had to reglue a bit with some 3M spray adhesive along the front edges, but nothing major. Did you get all the factory glue off when you replaced yours?
Here's a link to a thread with pics of how I did mine:
Turbo Cab gets new hood insulation
Old 03-19-2009, 07:51 AM
JohnKoaWood
JohnKoaWood's Avatar
I am sure you potoshop and defects out...
Old 03-19-2009, 12:56 PM
Luis de Prat
Originally Posted by flpaindoc
So I decided to go with this one: http://928leathershop.com/Hood_Liner_Heat_Shields.htmlI will let you know when i get it.
Looking good!
Be sure to cut a circle in the left panel, right above the brake fluid reservoir cap. This is to prevent the liner absorbing any brake fluid and doing a number on your hood paint.
Old 03-20-2009, 04:01 AM
PEvans
PEvans's Avatar
FWIW my body shop guy says if you use a liner get one that covers the center brace. It's this thing getting hot that can cause the hood to get out of shape.
Old 03-20-2009, 06:28 AM
Luis de Prat
I believe the center brace has foam insulation inside it. Or at least I noticed this on my hood when removing the factory glue.
Quick Reply: Hood Insulation
