Need replacment 951 Gearbox oil cooler pipe (uk)
Hi, had my gearbox rebuilt by Competition Transmition Services Ltd (Gearbox man)...No I dont reccomend them! Amongst other issues it looks like they have holed my oil cooler pipe. Anyone got one for sale or know of an aftermarket replacment?
Hi, thanks for the replies. SSI - I did some research on the Mocal oil cooler, sounds promising and would look alot nicer than the Porsche part. Can you tell me if the one you use is 115 or 230mm matrix and how many rows is it? What make of pipes do you use and what fitting are the unions?
The whole pipe wobbles in the lower hole and the top one is tight both with new orings. The slot where the retainer goes is mostly worn aswell as the retainer itself. You can see the wear right away when you look at it. I didnt think it was possible myself but i guess from years of being on there rubbing around it is.
Trans. Oil Cooler
We found on the track car the factory oil cooler was not cooling good enough witch would make the case exspand the pinion bearing race would spin in the case this would let the pinion move around then thing start to come apart. If you ever pull your gear pack off and the pinion bearing race falls out into case it over heated do to high gear oil temps.
