Quick release for bumper
Old 02-09-2009, 11:31 PM
Lorax
The Impaler
Lorax's Avatar
Default Quick release for bumper
I'm thinking about finding a way to mod my bumper to easily remove it, does anyone have any ideas or experience with this you would like to share?
It doesn't have to be super pretty, just functional.
Old 02-10-2009, 12:53 AM
aribop
aribop's Avatar
dzus fasteners
Old 02-10-2009, 01:54 AM
daigo
daigo's Avatar
Originally Posted by aribop
dzus fasteners
Old 02-10-2009, 10:37 AM
Weston Dillard
Weston Dillard's Avatar
I have noticed several race cars have gone to that, and intend to do it with mine. Most have ditched the 3 bolts that hold the nose to the fender and added small brackets for two dzus fastners on each side. The problem for me is I have brake ducts in the foglights. I'll probably go back to the original ducts that are supported off the tub and just run brake hoses off them. That way the nose detaches cleanly.
West
Old 02-10-2009, 12:15 PM
Lorax
The Impaler
Lorax's Avatar
West
I have brake ducts in those holes too, I plan on using some kind of quick release clamp.
Can you show me a picture or illustration of how they did it?
Old 02-10-2009, 01:46 PM
vette951s
vette951s's Avatar
Here are couple pics showing a fiberglass bumper attachment, but a stock bumper would attach the same with some trimming.
John
Old 02-10-2009, 03:55 PM
Lemming
Lemming's Avatar
I have a similar setup but using only two dzus fasteners on each side. Two more are used in the front.
Old 02-10-2009, 04:25 PM
reno808
reno808's Avatar
have any pics
Old 02-10-2009, 04:27 PM
Lemming
Lemming's Avatar
On my laptop at home, will try to post some up tonight. Car will be going to paint as soon as the rear flares are attached.
Here you go:
Old 02-11-2009, 07:21 PM
DFASTEST951
DFASTEST951's Avatar
Maybe this is easier to do but what about a full front tilt fron end so it could be worked on so much easier. It would also be much lighter as well. Has anyone ever done this? I think I've seen one once. I think that's the way to go.
Old 02-11-2009, 07:31 PM
MPD47
The Carnage King
MPD47's Avatar
Joe, the only time I've seen that is on the TTV8 tube frame car. I think most of these guys are interested in a removable bumper for loading on trailers and replacement when racing. Atleast, that's why I did it (identical to the above setups).
Lorax
The Impaler
Lorax's Avatar
If I had a tube frame front end and a LOT of time to spend I might consider it!
Old 02-11-2009, 07:44 PM
DDP
Rocket Scientist
DDP's Avatar
Clearly cost, cost and cost. Also, have you ever thought if you needed to remove the entire front end as one piece? You couldn't do it alone, first off. And second, if you're in a garage with only so much space, it takes up nearly half the car, where will you put it?
Old 02-11-2009, 07:51 PM
Lorax
The Impaler
Lorax's Avatar
FWIW he was talking about a front tilt type setup.
Old 02-11-2009, 07:55 PM
DDP
Rocket Scientist
DDP's Avatar
I understand that. But even a front tilt setup will need to be removed sometimes.
Quick Reply: Quick release for bumper
