Wheel bearing grease cap removal help
I'm having trouble removing the wheel bearing grease cap on the front wheels. Clarks garage says to tap around the back of them with a hammer and chisel but they aren't budging. Does anyone have some tips or advice for removing these? Thanks!
They are press fit into the hub. There is a lip that runs around the base of it. You can sometimes pry on this with a screw driver. Rotate it 90 degrees and do it again. It will eventually come off.
I have used a big pair of adjustable pliers to pry it off but find the best way is hammer and chissle. Just keep working around the outer edge a tap at a time. When I install I apply a little greese to the cap to help get off the next time
Ha! Part of my spring maintenance is to pull mine off and repack the bearings with some hi-temp synthetic grease. Those suckers really get hot over a session.
