Big red brake upgrade without the red - Interested?
Basic Site Sponsor
Basic Site Sponsor
OK, here's my contrbution to this issue. I happened to write an article to Porsche Club Finland Magazine about upgrading 951's brakes. While it's totally worthless to post the whole article here, mainly because it's in finnish......I made an excel sheet about caliper and pad differences.
Type...944t '87...turboS...BR/BB......GT3 '99-...GT3/GT2
Disc.....298x28...304x32...322x32 ...330x34......350x34
Caliper
attachment...A 94mm ....R 130mm.....R 130mm..R 142mm...R 142mm
pistons.........40/36mm...44/36mm... 44/36mm...44/36mm...38/32/28mm
area/cal side.22,73cm2...25.38cm2...25,38cm2...25,38cm2...25,54cm2
pad area......49,7cm2.....67,2cm2.....86,9cm2.....82,6cm2.....125cm2
minimum wheel..16"...........16"............17".............17"...........18"
A= axial, R= radial attachment to spindle
The difference between turboS and BR/BB pads is their height, 51,0mm vs 66mm both are 131,8mm wide. Ferodo has here: http://www.ferodoracing.com/it/download.php?type=8 application tables and drawings with measurement about their products. IMO Diver944's solution is worth thinking. Very cost effective.
Caliper
Pete
Power. Lots is good, more is better, too much is just right...
'87 951, RIP
'00 996 C2 L92U AQ / IXAA IXRB IX54 M96/7.xx G96/7.88 M030 M375 M376 M436 M476 M601 M983 ... + 991 GT3 brakes, 997 GT3 sway bars, fully monoball'd suspension, Bilstein Cup Car coilovers, do88 Big Pack ICs. 10 & 12 x 19" BBS CH-R wheels with 265/30 & 325 /30 -19 MPSC2s.
Pete
'87 951, RIP
I currently have the S4/951S caliper/rotor on my '87, with the axial/radial adapters. Can I just add the additional spacer and longer bolts to use with the larger rotors and no other conversion pieces needed?
I thought that the caliper also has to be ground a little to clear the rotor? If you look at Marks original thread he also had to do that. Does not seem to be a major deal, just grind away some material and away you go.
Caliper
Caliper
which shows why it's probably too hard to put the last two on later model 951s. I'd love a set of the GT3/2s but they won't fit. Alternatively you can opt for the race version of Brembos or similar PFC, StopTech, Alcon etc but they are very expensive and true overkill for 99% of our cars.
Basic Site Sponsor
Basic Site Sponsor
Actually we discussed this same issue over here during this weekend, and one 928-driver ( poor lost soul... ) is developing adapters for 6-piston calipers with 350mm discs, for a GTS. He claims that if there's more than 10mm of adapter required, it can be done. In other words, 330mm disc is too small, but 350 is enough. I haven't yet seen those either live or in pictures. Remains to be seen. The car itself is getting somekindofablower too.
Why not just change the spindles and use adaptors if you prefer to go six piston?
A lot of people track cars with non M030 spindles so certainly strong enough.And they are a lot better value...
Is that how you're doing yours Rod?
Looks like we have almost 5 guys to get an order together. the machine shop needed at least 5 sets to make it worth his time. The parts turned out pretty nice.
If everyone can confirm by PM, Ill get the ball rolling for the spacers and the bolts and get a price for just those. I think only a couple wanted the discs and pads as well.
Let me know.
mark
Let me know.
mark
Yes, this is the only caveat, but it is about 5 mins per side with a dremel and its only at the edges. Unfortunately, this caliper, that is the same size as the F40/F50 Ferrari caliper, is made for the little sub 12" rotor. and not the 14" found on the F50. so, a little area needs to be radiused.
mk
mk
That has nothing to do with the the pad coverage.
How did you do this? I hope you radiused the calipers and used spacers.
Did you pull the rotors and go back to stock rotors , as the calipers we are talking about using are the stock stuff.
It doesnt matter that the Big red pad is wider. as I mentioned, many of the top systems incorporate the exact same pad as the S4 pad. Namely, the ST40 Stoptech. the inner diameter that doesnt touch, cant be involved in vibration, as its not being touched . You need to mate the pad to the rotor via the spacers so that the entire pad is matched to the rotor. thats where the value of the spacers I will make will provide. they are perfect for a 2mm grind off the edges of the calipers and the pad is perfectly placed on the rotor.
mk
mk
One other difference, the big reds/blacks use a deeper pad holder. If you try and shove big red brake pads in a 951S caliper, they stick out the top and you can't shut the gate.
FWIW, I ran S4 calipers, and 3.6L rotors, and had horrible brake squeal (like ear shattering brake squeal). Tried numerous sets of different pads to no avail. I attributed it to the s4 pad not covering the entire width of the 965 rotor, but that was a guess. I finally pulled them and went back to stock calipers.
