Turbo head, 3.0 block ?.
I searched but didn't find, any pictures of a turbo head that's been welded/modified to fit the 3.0 block ?, something to do with the waterway I think. Cheers.
Thanks for replying, what's involved exactly ?, I know people use a 2.7 head if they can find one but surely the turbo head with the better exhaust valves and coated ports is a better option.
Of the OEM parts the 2.7 head is the best. After that you can spend all manner of $ on making the 2.5L as good or better...and to fit of course.
Maybe... but you can easily coat the 2.7L exhaust port and swap in sodium filled exhause valves. You have to wonder what the trade off is for a 2.5L ceramic lined exhaust port is compared to a portable head that has a CC designed for a 104mm bore?
It's not real scientific. You weld up the coolant passage in the head (upper left in photo), and you weld up the coolant pasage in the block. Then you run a restrictor in the waterpump (basically a thermostat with the center cut out), and Bob's your Uncle. There are much more elegant souutions, but my car has been running like this for 8 years. Don't try to use a Cometic gasket though, they will leak where the coolant passages are mismatched.
West
West
sodium filled ?? ever seen a standard 1 pound valve melt ??? if you want it good ones good stainless chev valves are the answer. but its better to make use of what you have if you get the 2 head gaskets in front of you you will understand whats required
Umm, the factory exhaust valves are sodium filled...as well as many of the hi-po chevy valves.
The sodium fill helps take heat away from the valve face and distribute it to the stem. My 951 and ZO6 both have sodium SS valves.
While I'm not sure what the exacture mixture is in a 951, my Z has a 78% potassium and 22% sodium mixture. One thing to be aware of is, as far as the Z goes, the NaK mixture is unstable and may spontaneously combust when exposed to air with 50% or higher humidity which is why you shouldn't open or shorten Z06 exhaust valve stems. In case you ever needed that random info....It may come in handy at a party.
West
West
Seriously though. Weld it up? That passage is not needed?
West
West
