Gear to gear boost changes
Freedom Enthusiast
I had a broken intake stud from a previous job when I put in a wastegate shim, manual boost controller and Vitesse chip.
I had the boost turned all the way up by mistake and developed a vacuum leak that I believe was at the broken stud.
I pulled everything and drilled and tapped for a new stud. I've got everything back together and it seems to be running fine.
I do have one thing that seems strange. The boost was increasing a little as I went from 1st to 2nd to third, etc. Now it increases a lot from gear to gear. I see 10 in first, 12 in second, 14 in third, and 17 in fourth. Is this normal with a Lindsey MBC and Vitesse chips?
What did you used to see before through the gears? It's normal to have less boost in the lower gears but you should see max by 3rd, even 2nd.
Drive-by provocation guy
The chips/maf have no bearing on your boost.
This is all your boost controller. Like 333 said, from 3rd gear for sure(should be 2nd also)
you should see the same boost within 1 psi.
You need to set your max boost in 3rd or 4th gear and then you will be fine and only see a little less in the lower gears.
Tuning affects boost to some degree. However the boost controller is in control! 3rd or 4th gear is about the only way to determine the boost settings (I prefer 4th). The trick is to get the engine under load. Outside temps could affect the results, depending on the boost controller in use.
Freedom Enthusiast
I'm using the factory afm with the Vitesse chips. It is running great, I was just wondering about the bigger changes in my boost levels and if this was normal.
I'm doing WOT runs on a straight road to see the levels listed in my first post.(it's way out in the desert with very little traffic for you safety ****') I'm granny shifting since my clutch seems to be slipping a lot more with the extra power.(Thanks John)
Fast shifts into second sometimes get wheel spin and sometimes get clutch slip. It was much colder when I was testing yesterday. Maybe that had something to do with it.
Vitesse+MBC+295 tires+old clutch=
I'm babying it until I get the new clutch in.
My idle went up to 1200 rpm after I ran it with the boost set too high. I turned the boost down to 16 in fourth. I noticed the increased idle a couple days later. I asked Jeremy Himsel about it and he told me to check for vacuum leaks. I was only seeing about 1 psi difference before I took it all apart and fixed the stud/leak. Now I'm seeing 2-3 psi per gear.
I'm doing WOT runs on a straight road to see the levels listed in my first post.(it's way out in the desert with very little traffic for you safety ****') I'm granny shifting since my clutch seems to be slipping a lot more with the extra power.(Thanks John) Fast shifts into second sometimes get wheel spin and sometimes get clutch slip. It was much colder when I was testing yesterday. Maybe that had something to do with it.
Vitesse+MBC+295 tires+old clutch= I'm babying it until I get the new clutch in.
And colder temps will usually result in 1-3psi higher boost especially in the upper gears.
Freedom Enthusiast
I fixed the broken intake stud which fixed the high idle. The broken intake stud is where the vacuum leak developed. Cold is a rare thing here in Phoenix. I'll wait two days until it's hot again and check it again.
Freedom Enthusiast
Would the person selling these take sexual favors from Jeremy in payment?
