FS- 26/6, Wastegate, Injectors, Chip, Center Caps...
I have a few things for sale. All are off an '87 951 with 100k miles. All items worked well when removed and I will refund any money if part is not as described (minus things that may have occured during shipping). I'm just a guy with a budget trying to recoupe some costs to purchase other things, and feel the prices are pretty good...and as always, I'm just trying to help others. All prices are OBO.
All stuff mentioned here made 238whp/248wtq in this car. That was with an LBE and chipset. No aftermarket exhaust or anything else. So this stuff is obviousbly in nice shape.
Wastgate. Worked well and held pressure pretty nicely with my LBE. No broken studs or cracks.
$50
Stock downpipe. No cracks or broken studs. The inside is NOT collapsed like some downpipes tend to do.
$50
Stock cat-pipe with good shape catalytic converter on both the main pipe and wastegate pipe. No broken bolts or leaks.
$40
Stock muffler. The tip is rusted and it has a hole near the tip that needs welded shut.
Cost of shipping if someone really wants it.
Stock 951 Injectors. They all worked fine and did not leak. I'd send them to witch hunter if I used them.
$25
2 sets of amber front turn signal lenses. Neither left side is cracked. Both right sides have cracks. I will seperate or give the best left and right to whoever calls em first.
$5 per lense.
Stock 951 crossover pipe. No broken studs or bolts, no cracks or leaks. Pretty nice shape for 100k miles.
$50
K26/6 turbo. Came off the car, worked well with stock AFM, worked well with Vitesse MAF kit. No bent blades. It does have a broken stud that I will remove. It needs a good detailing. There isn't any shaft play. Very solid turbo.
$100
Windshield washer motor without headlight washers. Worked when removed.
$10
Mint condition Center caps. These are concave, and fit your standard Porsche wheels (twists, cup 2's etc etc).
$40
Authority Stage II Chip for DME (doesnt include KLR chip).
$25
Buyer pays for all shipping, and I will try my hardest to get actual shipping costs for you. If you need anymore information or pictures about a part, post a response or send me a PM and I will try to get back to you asap.
Thanks,
Cory
$50
$50
$40
$25
$5 per lense.
$50
$100
$10
$40
$25
Thanks,
Cory
How the hell did you get that wastegate out without breaking any of the studs.. i think i broke all but one of them when i took mine out!! .
If you have any trouble selling that, i am pretty sure LR buys them as cores and will give you a store credit.
ok ok...I broke ONE! Lol the stud had been removed though.
And I believe the chip is 24 pin. I will have to double check later.
The caps are yours.
And yes, I will have to check with LR on their core costs. I AM wanting to get my head done like yours. Think you could PM me some details/prices for the o-ringing and steam vent?
The caps are yours.
I don't know who gets the chip. You (gt37) expressed interest first, but Rogue said he would actually take it first...
I will try to get shipping prices tonight or tomorrow. I will send PM's to you both later.
i need one of those amber lenses. when u say left are u referring to the passenger side. cause i need one good passenger side amber lense. if this is good let me know how much shipping is and can i paypal u the total amount
thanks
thanks
u can also sell your catalytic converter for a little more locally to a scrap yard. probably close to a hundred bucks. i sold mine last spring for $100.00 to a scrap yard
pretty sure left means left side if sitting in drivers seat. I will double check though. Both rights have cracks...one isnt that bad though. Well work it out!
And thanks for the heads up. If no one buys the whole cat pipe, I'll see about taking it to a yard.
Few more items for sale.
The hard coolant pipe behind the radiator. Nice shape, no cracks or leaks.
$15
Lindsey Boost Enhancer. Nice shape as well.
$30
Turbo Water pump with mounts. This pump is fairly new. As you can tell, it still even has a zinc coating on it.
$75
Also have a stock water line for the turbo. It needs sanded down and painted or re-zinced. No cracks or leaks.
$15
As always, prices are OBO.
$15
$30
$75
$15
Basic Sponsor
Cory, that's not a LR boost enhancer it looks more like the reliaboost
