Dualport wastegate...Really worth it?
#46
Monkeys Removed by Request
Come on, people; alot of hype on wastegates that just gets repeated.
Wastegates don't make power. Engines and turbos make power.
As far boost building is concerned, you put an LBE, or MBC, or an EBC if front of the stock wastegate, and you'll have all the fast boost build the turbo can generate.
Also, boost bleeding off at the high end has just as much to do with intake, turbo, and exhaust inefficiencies, as it has to do with a so-called "weak" wastegate.
I'm not repeating anything. I'm speaking from personal expeirence. Infact is was soo much different I initially thought I was holding ALL the boost till redline. I was still loosing a few pounds but, not nearly as much. Car felt much stronger.
btw who pee'd in your cheerios this morning?
#47
I run 19 to 20 psi boost on a 3.0 liter using the stock wastegate (yes, you're reading this correctly) and no boost bleeding or drop-off. Actually, I have the reverse problem: boost creep (had to modify the pipe, where the wastegate valve opens into, in order solve that problem)
Why? Because maximum effort was put into engineering the intake and exhaust with as little pressure drop through the system as possible.
Porsche knew what they were doing in choosing that wastegate: to keep power robbing back pressure in check, which is often masked when going to a "better" wastegate.
It is also difficult to dial in a single port wastegate as shown above. A dual port design is far better in every way and does not require modifying pipes to "mask" boost issues. The dual port use the turob's own boost pressure to keep the wastegate closed along with the spring, this allows boost to hit much harder.
A single port with gradually open over a longer period of time as boost rises.
A dual port will stay closed until you want it to open, making the opening time much shorter and thus more power earlier on. All of this is dependant on how you set up the boost controller.
If comparing a stock wastegate to an aftermarket run in single port mode, then there will still be some gain from something like a Tial due to the design of the valve and direction of movement. Tial's also allow you to easily swap springs.
There's a good reason Tial wastegates and such are not legal in PCA stock racing.
#48
Guys;
alot of us have to replace our wastegates because they are simple getting old. So, that's why we're all going to see some sort of an increase in performance, going to a fresh wastegate.
It's the same thing if we replace an ignition component, or do a valve job; we are renewing, and we feel the difference, no doubt.
And, I'm not for a second disputing that if we use a wastegate with a stiffer spring and/or the wastegate valve gets pressed into its' seat from the exhaust, that we will have a change (to most of us, for the better) in the way boost is controlled. But, that's what it is: the way boost is controlled, which can be done number of different ways; it doesn't have to be a wastegate.
When I read: "A DP wastegate WILL give you more hp even at stock boost levels", well, I just like to keep it real. It's like saying: "I change from a MBC to an EBC and I"m gettin' more power at the same boost levels", which is not so.
I know the stock wastegate system is a little wierd, but it optimizes the relationship between intake manifold pressure and exhaust back pressure. Another words: two 944 turbos achieving the same boost pressure; the one with the stock wastegate will most likely make more power than the one with the after-market wategate. Note, that does not mean that the stock wastegate makes more power, it just means that the after-market wastegate possibly masks an inefficiency somewhere.
#49
Guys;
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
#50
The Impaler
Guys;
#51
#52
eniac;
"A dual port design is far better in every way and does not require modifying pipes to "mask" boost issues."
I'm not sure if you're referring to my issues of boost creep. Boost creep can never be solved by dual port design or any other type of control for that matter.
"A single port with gradually open over a longer period of time as boost rises."
Just use a heavier spring and it will not open even in single port.
"A dual port will stay closed until you want it to open, making the opening time much shorter and thus more power earlier on. All of this is dependant on how you set up the boost controller."
You can do the same thing with a boost controller of your choice in front of a single port.
#53
theedge;
I never said anything about two 944 turbos, both with proper turbos and exhaust ,etc.
I just said two 944 turbos running the same boost.
That's the whole point: an aftermarket wastegate MIGHT mask an inefficiency somewhere, whereas the stocker shows a weakness right away.
Ya see, if it was up to me, I'd upgrade my airflow producing components so that I can get great results even with the stock wastegate and if I don't like how the boost is controlled, I'll swap out the wastegate or different boost controller.
#54
Well if two cars with the same mods,running the same boost levels with the difference being only the wastegate,the DP wastegate will make more power 99 out of 100 times.It will hit full boost sooner and make its peak torque sooner and will hold boost(the same amount of boost) longer in the rpm range which is the hp gain.
#55
I wasn't aware there was a place that sold heavier springs for the stock wastegate. Besides that, once any pressure is applied to the spring, it starts to open, maybe not much but it does. Also a heavier spring has it's own issues as well. I.E. boost creep and boost spikes in the lower gears. Maybe it's just me but I much prefer to reach down and change a few settings over getting under the car to pull the WG off to change a spring.
More adjustabilty and greater fine tuning + a better design = more power.
I do agree that replacing a worn stock wastegate with a brand new one will make most cars feel faster, but I also do know from personal experience that replacing an almost new(2 months old) stock wastegate with a Lindsey dp wategate using the same MBC at the same boost level made it feel like a different beast. The turbo spooled sooner and the low gear boost spikes were able to be dialed out with the MBC.
#56
#57
It's pretty tough to argue with real world results.
#58
TurboTim;
I'm not knocking a dual port wastegate; I think it's a great way to control boost.
But, if you install a boost controller (an EBC, for example) that stops any boost signal from going to a wastegate would it not achieve the same thing as a dual port?
#59
Besides, if one says "it will hold boost longer in the rpm range", then that's not really running the same boost levels now, is it. (Because, you're running more at certain high RPMs)
#60
It's not where you end up, it's getting that makes these cars so fun.
