Turbo making a new sound
Old 02-24-2009, 09:58 PM
Bri Bro
Bri Bro's Avatar
Found it.
Old 02-24-2009, 10:05 PM
David Floyd
David Floyd's Avatar
That would do it
Old 02-24-2009, 10:10 PM
Bri Bro
Bri Bro's Avatar
Well, so much for the $350 new bearing and balance job. Looks like it will be needing a couple of new parts that will add to the $$$.
Old 02-24-2009, 10:57 PM
gpr8er
gpr8er's Avatar
Any idea of the cause of the failure. Heat fatigue? I have a Lindsey Super 65 that I had to have the center section rebuilt because of a leaky seal setup after only 1k miles.
Old 02-24-2009, 11:09 PM
Bri Bro
Bri Bro's Avatar
Not really. I was running it hard at the time but the stock unit got the same treatment. It appears a blade failed and ground the tips off of the rest of them. I was thinking something came out of the head but the inside of the blades are in good order. I don't in any way think this is a Lindsey issue, just had a part failure.
Old 02-24-2009, 11:16 PM
Dougs951
Dougs951's Avatar
It could have been anything that got sucked in there. Maybe shake the muffler out and see if you can find it for interest!
Old 02-24-2009, 11:32 PM
Bri Bro
Bri Bro's Avatar
I think I will do that, it is just hanging there so it will be easy to do. If I find anything, I post up some pictures.
Old 02-24-2009, 11:38 PM
Techno Duck
Techno Duck's Avatar
May want to pull the headers off the car and take a look at the ceramic liners in the exhaust ports of the cylinder head.
Old 02-24-2009, 11:41 PM
Bri Bro
Bri Bro's Avatar
Good point. The headers were pulled to be coated , all looked good but I will get a bore scope and look at it in more detail tomorrow.
Old 02-26-2009, 09:54 PM
hally
hally's Avatar
Bad luck there Brian.
Let us know what you find.
Old 02-26-2009, 11:26 PM
hp18racer
hp18racer's Avatar
Looks just like mine. I found a piece of slag in the cross over pipe, ended up swapping the head and turbo. You definitely need to look in the crossover, headers and head to make sure you don't do the same to the next turbo.
Old 02-26-2009, 11:28 PM
theedge
theedge's Avatar
Wow thats some carnage.... A missing blade too
Quick Reply: Turbo making a new sound
