What is the biggest battery I can fit in my 951
I need a new battery very badly!! It barely had enough power to start the car in 30 degree weather. What is the biggest battery I can fit in a 951. It would be nice to have atleast 800 cold cranking amps if possible
It was a while ago (5 to 6 yrs), however I remember putting in a sears battery that was 1300 cold cranking amps and the same size, but slightly longer. This was OK, as there's enough room.
My Diehard group 41 (the one they list as the one for 951s) has started my car in MUCH colder weather with 20W50 oil.... You probably just need a new battery period. It started it easily at around -10F.
Our cars are low compression 4 cylinders; they aren't too hard to start. Sounds like you need a new battery and possibly cleaning of the contacts on the grounds and/or starter.
I have a small race battery in my car and it will crank fine even in cold weather (as long as I haven't left the alarm on for more than 2 weeks between starts).
