so im putting my engine back together and ran into a little trouble
I am guessing the balance shaft delete is universal? They only changed the bearing bridge between 86 and later. In 1986, the outer bearing bridge bolted on to the block, then you installed the balance shaft cover. In 1987, that changed ,and the outer bearing bridge was built into the balance shaft cover, which eliminated that one part.
I don't know what the difference is on the BS delete kit, but you might want to pull it back apart now and get the correct kit for the 86. Would suck to get it in the car and it starts puking oil, or there is a feed issue to the turbo.
