so im putting my engine back together and ran into a little trouble
I bought a block from a 88 Porsche turbo s. The block didnt come with the oil cooler. So im replacing the oil cooler with the one off my car and that was a 87 turbo. the problem is that the blot hat sticks out of the oil cooler with the O ring does no slid into the new block. Any imput?
Do i need to source a bolt from a turbo S?
![](https://photos-d.ak.fbcdn.net/photos-ak-snc1/v373/186/18/577998366/n577998366_1166803_5932.jpg)
![](https://photos-c.ak.fbcdn.net/photos-ak-snc1/v373/186/18/577998366/n577998366_1166802_5413.jpg)
![](https://photos-g.ak.fbcdn.net/photos-ak-snc1/v373/186/18/577998366/n577998366_1166806_7457.jpg)
thats as far as it goes in :/
Geaux Tigers!
Does it appear that there's a sleave on the block that makes the hole smaller? Last, how certain are you that this is a S block? If no sleave and it's def. an S block then allignment may be your issue.
What are the block stampings on the drivers side of the motor near the flywheel end. Also, the oil cooler is loose from the block still correct?
m44 / 51
45609179
no i bolted on the oil cooler too the block and pulled the bolt from it so i could aline it without the huge oil cooler on there. didnt work though :/
45609179
M44.51 is a non turbo S block. Are you sure the 6 isn't a G. If I am remembering correctly, 1986 is a G code, H is a 1987 and so on. Usually the engine serial starts with 45, then a letter indicating the year, then the rest of the number. Sounds like you might have a 1986 turbo block, in which case you need to use the earlier style OPRV.
Nah, you just need to find an early style valve now. Did you have the balance shafts apart? If you are building the motor from scratch, make sure you used the 1986 balance shaft bearings as the covers and bearings changed in 1987. If you didn't touch that part of the motor, or didn't replace the bearings, then disregard.
lindsay racing balance shaft delete
so this block is from a None S from what year? i need to order the the baffle kit for the oil pan i was under the assumption it was a S and they addressed that problem a bit beter.
The 3rd digit in the serial number I am guessing is a G (It should be a letter, not a number), not a 6 if you look close, would would indicate it is a 1986 turbo block. Also, I am guessing there is no auto tensioner for the timing belt on the front side, which would also indicate it is a 1986. That would also explain why there is a sleeve in the block for the OPRV, and why the later style OPRV won't fit.
