Track day at 37 degrees! - interesting
Monkeys Removed by Request
Definitely like this setup.
Car feels very good at 15 psi - that is my base minimum setup (1 bar wastegte spring)
nice and smooth to street drive, with plenty in the mid and top when you want it.
full boost - I would guess 3400 RPM give or take... On the track it seems instant as rarely are you ever under 3500.
also the power is fast but smooth.... the bursty *** 26/6 before would frequently upset the car on corner exit if you rolled into the throttle early, this is so much better to drive fast, much more power in a wider range that you can modulate
