Tire size help..
Old 11-06-2008, 04:23 PM
Judson951
Judson951's Avatar
Default Tire size help..
Ok I have been talking with several people and still cant decide what tire size to go with. I have an 86 944 turbo. I just bought some new rims and need to find the right tires for the front and rear.
The front rims are 8.5x18 and the rear are 10x18.
I am leaning towards a 285/30/18 rear. But what can I fit on the front? What ever I get I want to make sure they will not rub at all.
Let me know what you think.
Thanks,
Jusitn
Old 11-06-2008, 04:45 PM
333pg333
333pg333's Avatar
I'm sure you could get 255/35s on there. I have them on my 9" fronts and it's very low and I don't get rub although I have pretty a pretty firm suspension setup. Check the guides on Tirerack. They show what size rims the tyres can be fitted to. Oh, I have 285/30s rear too. No probs.
Old 11-06-2008, 04:48 PM
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
im late offset
235 front 295 rear
Old 11-06-2008, 07:45 PM
Mike Buck
Mike Buck's Avatar
what are the offsets?
Old 11-06-2008, 08:58 PM
purple_rado
purple_rado's Avatar
Justin, with the right offset you should be able to fit a 255/35 no probs. worst case a 235/40 would look pretty beefy on there too! whatever the case post pics of those wheels as soon as they're in your possession!
-vic
Old 11-06-2008, 08:59 PM
xsboost90
xsboost90's Avatar
i would go 245/265 or 275- make the stagger closer. Better handling and less worry about rubbing and tramlining...but what do i know.
Old 11-06-2008, 10:36 PM
333pg333
333pg333's Avatar
I agree. You don't want them too far apart in widths. 255/285 should be fine. Be careful though about the rolling radius of the tyre. Often the fronts can be bigger than the rears and you don't want too much differnece there either. Again, info available on places like Tirerack etc.
Old 11-06-2008, 11:02 PM
Judson951
Judson951's Avatar
The front is ET 40 8.5" and the rear is ET 25 10".
Old 11-07-2008, 02:25 AM
porshhhh951
Originally Posted by 333pg333
I agree. You don't want them too far apart in widths. 255/285 should be fine. Be .
can you elaborate on this more patrick? Should I change my tire sizing?
Old 11-07-2008, 03:51 AM
333pg333
333pg333's Avatar
Well it quite possibly doesn't matter that much if you're just cruising around on the street, but with your upgrades introducing some pretty serious power you might want to get the widths a bit closer. Having said that, if they've been working fine to date then just ignore me. The common school of thought is that our cars have built in understeer. In fact probably more than 90% of all road cars do as well. You will see big staggers on rear engined Porsches, but that's because they have so much of their weight over the back wheels. With our virtual 50/50 balance it makes sense to also have more parity with our wheels/tyres. As you would know, many racers actually use the same size front and rear on 944 cars. This may also be partially a financial decision, but even looking at more top end guys like Hans B, he uses almost the same front to rear for his dedicated trackcar. I will be most probably using 285 all round next season for the track. Even now with 255/285 I get a fair bit of understeer, and I'm trying to figure out the best way of dialing that out. Mostly slow to medium speed corners, but it's really annoying. What size are your front wheels John?
Old 11-07-2008, 07:39 AM
porshhhh951
I don't remember but, I believe 8.5in
Old 11-07-2008, 08:22 AM
333pg333
333pg333's Avatar
I think you should try something a bit wider on the front John. If you've got 8.5" you should be able to go up to a 255/35 I think.
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
255/35 for an 8.5" rim.
Old 11-07-2008, 09:25 AM
evil 944t
evil 944t's Avatar
255's on 8.5" rims fit perfect.
Old 11-07-2008, 10:15 AM
LUCKY DAVE
LUCKY DAVE's Avatar
Location: Encinitas, ca PCA National DE instructor PCA San Diego chief driving instructor
I run with pca in the San Diego region. We're the largest and most active in the country with 2600+ members and year round racing weather.
As you might imagine, there are a ton (more than 50?) 944 track cars being run here. I only know of 1 guy that runs staggered wheel/tire sizes, and he has an understeer problem.
You do the math.
btw I'm running 275/40/17's on 9" rims with good balance.
Old 11-07-2008, 10:21 AM
Antonio951
Antonio951's Avatar
I have 8.5 wheels up front and 10 on the rear. 225.40.18 Front and 285.30.18 Rear.
Quick Reply: Tire size help..
