X-post: Buying a TIG welder, need a little advice
#33
Freedom Enthusiast
Kevin,
I'm sure you don't want to hear this but, save your money and get this...
http://www.millerwelds.com/products/...ty_200_series/
It can make a 3 year old weld aluminum. I use a syncrowave 250 and I'm ready to sell it for a new dynasty. You can get the base model and add on. They do great with a water cooled conversion.
It sucks to spend the extra money but in this case, you get what you pay for and a good welder will help you weld better.
Well this thread was fairly amusing, so it's back.
evil 944t- There is a local guy selling a Dynasty 200DX with foot pedal, torch, and about $250 worth of various filler rod for$2k. It looks to be in great shape, but I need to go back there and put a plug on it to make sure it works and check the hours. How many hours are reasonable for the price?
#36
#37
Team Owner
Went through this exercise for our maintenance dept. last winter. Already had a TIG bought a few years back when lead maintenace guy was a super welder. He had been a certified welder for Boeing RD shop in Seattle once upon a time. He was gone and I was only guy with any TIG experience but many years ago and no time.
I bought them a new Miller Mig that is dual voltage. Has shorter duty cycle and lower amperage when 110 but full duty cycle and full amperage when 230. Welds stainless (repaired #2-3 exhaust on my 951 with it) and aluminum super plus for light repairs has advantage of plugging into 110 around the plant. I'll check out the model number tomorrow. I know it was less then $2k.
#38
Good, maybe I won't even know that I'm a terrible AL welder. So is there a number for hours on the machine that I should walk away from?
#39
I did and inlet manifold years ago for something with a AL set up MIG the welds all looked spot on but when i pressure tested It had fine porosity ...basicly i concluded that with a modest Mig set up you can good looking structurally sound aluminum but not tanks manifolds etc ...
If you have the space and the power its cheaper to go seperate AC and DC rigs and leave them set up if you go ol scool big **** AC and pilot arc ...that is
depending on your MIg you may be able connect a torch and DC TIG somtimes welder repair shops will do a mod for voltage control ...... but I'm curios you may be able to just get a pedal +torch...
#40
