What's the best repair for a slightly bent car?
#47
Boy, I've seen some great avatars lately. Keep it up guys! ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I took the car to a friend's body shop yesterday. He agrees with all of you - its worth putting it on a frame machine. He works with another shop which has a machine - we're going to call them next week and see if they have, or can rent, jigs that will work on the 944.
So, that'll be the next step. Hopefully this shop will let me stay around while they do the work so I can take pictures.
#49
So, I dropped the car off at a reputable frame shop yesterday (nice, clean facility, too!)
They think it's quite doable to "make it right". Their technician said he did a little "944 research" - and his material says that there are pinch welds under the plastic rocker panel trim - and he'll be able to hold onto the car there. We'll see if he's right.
As for the price, I imagine it'll be more than I was hoping for, but if they do a good job, I guess it'll be worth it. Their rate is $125/hour and they're guessing it'll be 4-6 hours.
The looked pretty busy, but might have it done in a week or so.
then the question will be, pay a shop (my usual body shop) to do the finish work, or do that myself over the winter. I guess I'll make that decision when I get the bill from the frame shop.
#52
#53
Edit--sorry, I misread your post. I would agree, $750 isn't unreasonable. Its a common misconception that frame damage is what drives repair cost sky high when it really doesn't. Our frame rate is only $5 more than our sheetmetal rate. If your just getting a pull or two done its not that expensive. Parts, paint and things like airbags run the bill upwards very quickly though.
#54
Going with the pack
is quite monotonous.
Originally Posted by Lorax
I'd say that car has a solid 8 hours of pull time on it, being generous. I can't see the car so I wouldnt want to under estimate.
Do you do estimates for a body shop? Do you paint? Have you painted professionally? Have you repaired frames professionally?
#55
Yeah - that's his regular rate. Obviously, I'm not using insurance... I didn't ask, but I wonder if he'll offer a slight discount for cash. It was a nice shop - clean and well staffed. All of the cars in there were new-ish and they were high-end models (Mercedes, Range Rover, Lexus, etc). I didn't see the names on his frame machines (he had 2 - one larger than the other - the smaller one looked like it had rams at each of the 4 corners - the larger one was tilted and had 4 rams at one end.)
#56
That is the highest body shop labor rate I've heard of. Definitely would have to be working on high end stuff, everything else will total with rates like that. I'd love to see the faces of the local insurance company guys when they stroke those checks. It never hurts to ask for a cash discount, make sure you're asking the owner and do it when you drop off, not when you pick up. I wouldn't be surprised if he says no (unless he knows you).
#59
I spoke with another shop - perhaps one that has a lower labor rate. They said they used to be able to rent model specific jigs, but no longer. They were concerned about working on such an exotic car and the referred me to the shop that's doing the work. One of the best indy Porsche shops also recommended this shop - so I have no doubt that my car is in good hands.
That's amazing the national average is $55. I just looked up the national average salary - a few years ago that was $36,700. I can tell you, the average salary around me is higher than that... The local run-of-the-mill mechanics have labor rates of $75+, and the high end shops are $105 and up.
