Motec all the stuff i never realised i must have
After a string of emails to the very helpful Motec development engineer I find there are all these features that as they never occurred to me I never needed but now I know I just cant live with out them and I'm dreaming about them before i even get it running .
traction control multiplexer so i can set up launch control traction control gear indication boost per gear ground peed limiting .with just 1 input
and then correction tables by aux input allowing me to do such things as
fuel quality switch or detune according to gearbox temp or cyender head temp or driver jock strap moister read out
Knock retard/ boost cut
I'm able to resist the dash but I'll probably will go to the motec training seminars
I avoided Motec for years for this very reason of tragic addiction
using the motec as a boost controller and then, boost by gear / sort of a traction control, is my next motec tuning project. Then on to maybe a true FQS switch for E85 / race / pump / so never have to "find" a pumping station.
But I will never limit tuning to temps. that's a bandaid. just make things work cooler naturally. maybe just sme warning lights to tell me to pit and fix the problem.
yeh gear selectionis just figured as driven wheel v engine speed and traction is driven v undriven or ground speed . so it can be done with 1 front 1 rear input but there is also a muliplexer that combines the signals into single digital signal the ecu can decipher all the wheel speeds from on input you can then use the other inputs for clever things like exhaust manifold map reading .
Thingo you do have a problem you've got more Motec boxes than me and 950NE combined .
an ethanol sensor is interesting idea but how about when you put a lot of tolulene moon shine in
