I love my new soild trans mount
#31
Oh nice site, lots of goodies there I have been looking for.
I love the disclaimer:
"At OnlineMetals, we all failed shop class. Multiple times. As a matter of fact, our employment applications specifically ask to see people's grades for their high school shop classes. If they're too high, they go into the rejected pile. We're also not engineers, and cannot make any specific recommendations about the suitability of a given alloy, temper, or shape for your project or application."
#32
Isn´t it a must to change to solid motor mounts also when using solid trans mount? Otherwise increased load on the trans mount and torque tube because of engine/transaxle movements during acceleration/full throttle->of gas pedal?
I think of the engine and transaxle as a rather stiff unit that is fixed in one end only in that case.
#33
Perhaps a solid transmission mount will increase the life of the stock motor mounts, since they no longer have to compensate for transmission movement. On top of that, I doubt that new motor mounts allow much engine movement to begin with.
#34
The early style dual mounts were still rubber mounts though. It prevented swinging, to a degree. And it still absorbed vibration. A solid trans mount would put more load on the motor mounts because that would be the only soft spot in the drivetrain's mounting. I.e. the path of least resistance for vibration and torsion.
What about the trans support rod from that other thread? I think xsboost and some others came up with a nice design to connect a rod from the driver side of the tranny to the crossmember, diagonally, to stop swinging. Maybe PU filled mount can be done in addition to this? Even a PU filled used mount?
#35
The solid tranny mount still allows some flex (the trans mount cross-member isn't rigid); just as much flex as the early style mounts.
#36
I think the early mounts still are more forgiving than a solid late mount, and I think a support rod would make it like an early setup where the cushioning is there, but you're right it would still send most of the torsional stress to the motor mounts. But the support rod setup would still load the motor mounts less than a solid mount IMO.
#37
Does anyone have the dimensions of the transmission mount (stock or aftermarket)?
or, If anyone has one laying around, would they mind taking the measurements?
I'd love to make my own mount.
I have access to a mill, lots of cheap aluminum, and I'm a decent machinist.
Also, I couldn't find the transmission mount on the DPS Motorsports ebay site or on their website...
#38
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I am not usually negative on Rennlist….but…
Solid transmission mounts are really annoying and only allow you to abuse parts more.
Sure, if the stock mount is old you should replace it – but this is not like a ‘normal’ vehicle, the engine and transaxle are solidly bolted together – and the shifter is mounted to it also. If your stock engine and trans mounts are in good shape there will be no benefit to the shifting or any other stuff.
If you really like the sound then fine, that’s up to you, to me it is not enjoyable, I would rather hear the engine! If you want a race car then build a race car, if you want your street car to sound like a race car….then you must not know what a real race car sounds like….
They rattle, creak, groan, squeal, chirp and make all sorts of noises that would embarrass me out on the street.
Sauerkraut with a side of rice is not a nice dish…
#39
The last time i saw my tranny mount was 2 years ago during a clutch job. I probably should have replaced it then as the trans is really swinging around back there now.
Can I get the mount out w/o dropping the trans?
#40
#41
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#42
