shift @ what rpm (POLL)
Lets get a poll, now this is for legal hwy driving:
1st to 2nd=___________rpm
2nd to 3rd=___________rpm
3rd to 4th=___________rpm
4th to 5th=___________rpm
Also what gear do u use at a constant 25 mph?
For regular driving around town:
1st to 2nd= ~3500 rpm
2nd to 3rd= ~3500 rpm
3rd to 4th= ~3000 rpm
4th to 5th= ~3000 rpm
Sustained 25mph is done in 2nd
Chainsaw
I shift when I shift. Don't really have a standard as the [non] poll might have as an option.
With a full tank of gas, I'm a little higher in the RPMs. Getting close to empty, I'm more conservative in my spirited driving.
Most of my driving is on an AX course anyway and then I try to shift just before the rev limiter kicks in.
1st to 2nd=___________rpm Doesn't matter, whatever, no traction anyway
2nd to 3rd=___________rpm When the computer decides I'm going to fast and cuts fuel
3rd to 4th=___________rpm When the computer decides I'm going to fast and cuts fuel
4th to 5th=___________rpm When the computer decides I'm going to fast and cuts fuel
That would be 6900rpm or 35psi boost, whichever comes first. When I'm done accelerating I shift to whatever gear keeps the engine at 2500-3500rpm I guess, I've never really thought about it. Shifting at XXX rpm is not a good idea. Many other factors decide what gear you should be in at a given time. Just go by feel and listen to the car, it will let you know when to shift and what gear to be in.
Also what gear do u use at a constant 25 mph? 2nd
oh umm and will a 968 tip trans fit in a 951?......don't answer that.
Location: out in the sticks and flat lands of va wondering around for an open field or pavement!!!
1st gear ...just gets me rollin
2nd gear .... to my engine's redline 7300
3rd gear ...." "
already ova the legal speed limit
4th gear ....." "
5th gear ...." "
(of course only on a track ) for the street most of the time prolly about 5500rpms
To please Ehall my cayenne automatic of course shift when the the lil transmisson module says so ....
3rd gear ...." "
4th gear ....." "
5th gear ...." "
