Help me Rennlist/Black smoke on boost/Running rich/some pics
Old 09-02-2008, 10:50 PM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
Default Help me Rennlist/Black smoke on boost/Running rich/some pics
Hey gang, I am trying to fix the last nagging issue with my car.
The car runs rich, very rich. I average about 18mpg mixed city highway. I recently drove to Road America and back, and got about 350 miles and still have about 1/4 tank left according to the gauge. Thats 90% highway driving. I feel like I should be getting more. I put in a brand new O2 sensor, new fuel filter 2 months ago, and a good set of injectors from Schwank, which were cleaned and flowed by witchhunter installed last Nov.
When I was on the highway and would hit boost, my friend said he could see black smoke coming out of my exhaust.
I have recently gone through the engine, and replaced a bunch of stuff including AOS seals, and installed my Saikou Michi catch can.
Before I changed the AOS seals I used to get some milkshake in the filler tube, but since the seals were changed its bone dry. I have ran the CC for about 2 months now, and I recently checked it and there was not a drop in there.
I know the seal under the turbo is leaking, since I can see it smoking a little when the engine is hot, but that could be because I changed the all those seals around the turbo 2 months ago and could have not torqued it properly. I'm going to drop the steering rack tomorrow to see if I can tighten them down.
What else could I check? I checked/set the FQS switch yesterday, it was at 0 and I set it to 2 to see if I can lean it out a bit, but the car backfires like crazy still. Every shift I get back fire. its getting annoying.
My friend thought maybe the rings are bad, but the car only blows smoke under boost, and runs VERY strong at 17-18psi.
I read a couple of posts saying maybe the Bypass valve could be blown, but I can hear it working with my MAF pipe.
Getting a wideband gauge is next on my list, but that wont be for a few more weeks, and I have a feeling is all that is going to tell me is that I'm running rich still.
Here are some pics from this weekend......
Silver 933 belongs to John (Glen Watkins) Extra Black 951 (mine) Other Black 951 belongs to Phil (PhilR)
Old 09-02-2008, 11:08 PM
fbgh2o
Odd Posts
fbgh2o's Avatar
Assuming that your gauge is perfectly accurate you got over 22 mpg, if it is pessimistic (like both of mine) it is likely over 23 mpg.
I don't know enough to comment on the rest, but just thought that I would say that does not seem as bad as you might think. Do the spark plugs reflect that you are running rich?
Old 09-02-2008, 11:16 PM
Mighty Shilling
Wax On, Wax Off
Mighty Shilling's Avatar
In my experience, turbo cars all (including my parent's BMW's) do a small puff of black smoke on a shift or startup... I know I get a little, and my car (according to Colorado state emissions) is in perfect tune right now.
Old 09-02-2008, 11:21 PM
Spidey944
Spidey944's Avatar
Been practicing your flame throwing for next year Geoff??
Old 09-02-2008, 11:36 PM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
according to my buddy John, it was no small puff, more like a steady stream of black smoke when I hit boost
Old 09-02-2008, 11:50 PM
Mighty Shilling
Wax On, Wax Off
Hmmmmmmm... Kurtis does that one...
Doug, naw. that 151 is brutal.
Old 09-03-2008, 12:10 AM
DDP
Rocket Scientist
DDP's Avatar
Get a wideband and a piggyback. Wheels look nice.
Old 09-03-2008, 12:41 AM
Techno Duck
Techno Duck's Avatar
I put about 700 miles on my Saikou Michi catch can, mostly to and from work..nothing crazy and nothing came out of my catch can either when i checked it a few days ago..seemed completley empty. I just finished a track day.. so 100miles or so of pretty much on boost the entire time. Will check it in a day or two to see if anything is in there.
Old 09-03-2008, 01:14 AM
Rock
Lazer Beam Shooter
Rock's Avatar
Do you have autothority chips?
My car does, and does exactly everything you described AND gets roughly the same gas mileage.
My eX gf's turbo could easily rock out almost 500 to a tank. I barely got 380.
Old 09-03-2008, 01:33 AM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
no autothority chips here, I have the maxHp chips burned for my MAF.
Thanks Derek! I have some Q's for u, let me formulate them and I will PM u.
Old 09-03-2008, 08:21 AM
black944 turbo
black944 turbo's Avatar
Your engine is probably fine. You are probably running a bit rich. I was having the exact same issues with my lindsey maf. Any car when floored should go rich. Get a wideband or strap it to the dyno. If the car runs strong, you are probably fine just need to tune it out.
Old 09-03-2008, 10:55 AM
Papamurphdog
Papamurphdog's Avatar
Nice car. +1 on the wideband O2. Stop trying to lean it too much, it will be fine on the rich side. Clean the plugs before you track and run 100 octane race gas. You shouldn't run 18psi+ on the 93/94 pump gas for a lot of reasons, but for one the extra octane will help the charge burn better and it will make more boost and HP; it will seem like it is leaner even though there was no adjustment. If you can find higher octane, run it! As soon as I go back to 93/94 mine seems to be more pig rich than when I run a tank of 100. FYI, I get .20 extra BAR of boost with no adjustment on 100. Of course, bad advice if the car is a daily driver!!! In that case I'd still tune on the rich side to be safe under boost...
Old 09-03-2008, 11:01 AM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
this is a street car right now, no track ambitions yet.
which piggyback can I use with my scivision MAF?
Old 09-03-2008, 01:21 PM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
Originally Posted by gordello1
Get the Maxtronic & Maxtune combo. I've seen and ridden in a car with this combo with the Scivision MAF. You gain total control over all timing and fuel maps with this setup. You will need a wideband with a datalogger to know where adjustments need to be made.
No thank you. There has been more than 1 person having problems with their maxtune, I know sharky47's and MichelleJD's crapped out.
I really try to stand by Russell, but he is either very reachable or VERY UNREACHABLE.
I will not buy something as imortant as a piggyback tuner from someone who is doing this as a hobby. next.
Old 09-03-2008, 01:57 PM
gordello1
gordello1's Avatar
I hear you on that. It's too bad that Russell's reputation has suffered badly this past year.
Quick Reply: Help me Rennlist/Black smoke on boost/Running rich/some pics
