Turbo removal
Old 08-17-2008, 03:05 PM
  #46
Darwantae951
Darwantae951's Avatar
Originally Posted by MrPorsche951
I am going to reallign the intake, injectors, and throttle body tomorrow. I will first try the TPS idea.
If everything bolted down then there is no reason to "re-align" the intake and stuff. You can't really bolt them down and have issues. The only thing you can do that I can think of is put the gaskets on wrong and block the injectors.
Old 08-17-2008, 03:06 PM
  #47
MrPorsche951
MrPorsche951's Avatar
Darwin, read my other thread. thanks man
Old 08-17-2008, 10:27 PM
  #48
Schuepbach
Schuepbach's Avatar
Originally Posted by hosrom_951
Removing and installing the turbo is not really bad, but just like what everone said, there is so much you can do while you are in there.
Ya I just pulled mine, along with the AC Compressor(gonna do an AC Delete) and the steering rack(needed a new one anyway). And the only reason I'm pulling the turbo is because I bought the Lindsey 300 RWHP kit. And I figured while I have the exhaust and turbo out why not do the clutch and flywheel. And if I have the clutch and flywheel out, why not get some transmission work done....
ya theres a 944 turbo sitting in pieces in my garage...
Old 08-18-2008, 01:33 PM
  #49
Spidey944
Spidey944's Avatar
After seeing all the kick *** cars at the Fest this weekend, I am dropping my engine this fall for sure. Much needed cleaning, replace a few things, including main bearings, and if I can find a 27/8 why not drop that in there too!!
When I grow up, I wanna be just like Dan J!
Old 08-18-2008, 02:00 PM
  #50
Darwantae951
Uh oh...Spidey isn't a member anymore! I agree, when I get home, my engine is coming out and a GOOD cleaning is in order!
Old 08-18-2008, 02:33 PM
  #51
Spidey944
Spidey944's Avatar
I just renewed b4 it ever even ran out! Hey Internet Brands, get ur stuff together!!
Old 08-18-2008, 02:35 PM
  #52
Papamurphdog
Papamurphdog's Avatar
my brother herd a "POP!" sound under my fuel injectors when I turned it over. The fuel injector closest to the windshield is in deep and the others are not. Should I be able to see the yellow ring on the injectors? I belive (praying on my hands and knees) that this is my problem.
Before my injector connector fix, it would sometimes give a little backfire fart before dying. I now attribute that to the injectors shorting -- which is now fixed. Since you've had the clips on and off the injectors sooo many times I'll bet ya your hundo that one or more of the connectors is shorted inside the boot. See my other post from today... give it a try.
Quick Reply: Turbo removal
