Any one have a diagram of the block? EDIT: verify please?
I need a diagram of the block, birds eye view, need to see where oil and water passages are. I have a leak in the back of the head (oil) and want to see if there is a passage there... if not I am not sure where it is coming from (no its not the cam tower or that piece on the back of the cam tower).
Thank in advanced.
Ian
Thank in advanced.
Ian
my head and block have been decked. it is leaking because we re-torqued the head with a mls gasket. Just wanted to make sure there was a oil passage there and not a crack in the head or some thing.
To further elaborate on the oil passages. The four square holes are non pressurized drain holes and the one round hole just in front of the rear most drain hole is the pressure feed for the head/cam tower.
Thanks, that is actually very helpful. I hope I am not starving the head and cam tower. Luckily the leak isn't very big, I am just afraid it has been leaking into the drainage then.
