Is it okay to MIX OIL ?
I don't know what oil the clowns at the dealership put into it, I have 15/50 GTX Castrol ready for tomorrow.
I am low on oil now, I have to drive an hour away to get an oil change and inspection done.
I don't know what oil is in her now, is it better to put a bottle of 10//50 oil in.... or run her low.
You can mix; it doesn't matter.
You gotta remember that even during an oil change there's probably at least half a quart (probably more) left of the previous oil. And then people add different brands, weight, mix synthetic with dino, whatever.
If you add that much during a normal oil change, it will be overfull as some old oil will be left in the oil cooler and engine. I add 6 quarts then check the dipstick. If it shows near the full mark I start the car and let it warm up some. I then check the dipstick again and add the little extra needed from the 7th quart.
So yeah, you do need 7 quarts but don't just dump all 7 in without checking how full it is after 6.
There is nothing wrong with mixing oil. Synthetic blends are simply synthetic mixed with conventional. And if you mix 1 part 10-30 with 1 part 10-40 you get 10-35, as an example.
Change your own oil!
I never understand why people want to belittle technicians like they're a bunch of knuckle draggers. A good percentage of them are extremely well trained and have more mechanical skills than most people would ever dream of. I just finished my technician certification not too long ago and it's not a walk in the park, let me assure you.
