The GOOD, the BAD, and the UGLY
EEK!!
I agree, time to upsize.
Wow that stinks. Hopefully nothing made it into your engine.
You should look into one of the small aftermarket turbos like a Lindsey 48 or a SFR Stage 1. Running at stock boost they shuold give you better boost response, maybe a small hp increase without stressing your engine and you have a brand new, modern technology turbo.
I am looking at alternatives, will make a couple calls today and get something ordered. I have only got 2 1/2 weeks until I am back down there so the clock is tickin'.
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I am leaning toward the SFR Stage 1. Any opinions good, bad, or indifferent? It seems to be a relatively straight forward bolt-on application with only having to cut down the jboot. Anyone have experiences with this turbo? I need to order something by tomorrow.
Part of the IN Crowd
I have one. It is a fine turbo. Spool is fine. You have to bend the hard water line over the compressor to use the stock hoses but other then that it bolts up fine.
I took the turbo apart just for kicks. I think I will bolt the turbine housing to my trailer wall for decoration.
Oh, and the rebuilder saw the pics and says it looks like a typical shaft fatigue failure. FWIW
Regardless of the rebuild, the turbo was 20 years old with 96k miles on it. Not exactly the same as a brand new turbo so that point is, well, pointless.
edit: referring to the 20 hour comment, not Nize's.
I've got a call in to Tim at SFR.
Kool, did your Stage 1 SFR have the round oil return hole on the bottom? So you can use the stock o-ring, or did you have to get one of those adapters to seal the turbo to mount oil return?
