How to I get this Pin out
Part of the IN Crowd
Ok guys
I am trying to take my front cover off of my motor and cannot get the tab for the crank pulley out of the crank. Crappy cell pic below.
![](http://i225.photobucket.com/albums/dd80/Porsche951turbo/0511081436.jpg)
What is the trick?
What is the trick?
Thanks Derek I will try that. Mine doesn't seem to want to budge.
Here is another question for everybody. Did anyones engine smell strongly of burnt oil when you pulled the pan off? Mine has a smell of burnt oil especially near the oil pick up tube.
They are called woodruff keys (for some reason?). The groove they sit in is moon or scoop shaped, so if you tap it with a punch and hammer on the end it will often slide up and out without damage. Or, you can tap a sharp chisel into the end an pry up up with a little leverage. Or you can use plyers like these to wrestle it out http://www.harborfreight.com/cpi/cta...emnumber=38496 A touch of heat on the crank can help too.
And yes, I suspect you are describing the normal smell of a well-used crank case. The tranny is even better...
They are called woodruff keys (for some reason?). The groove the sit in is moon or scoop shaped, so if you tap it with a punch and hammer on the end it will often slide up and out without damage. Or, you can tap a sharp chisel into the end an pry up up with a little leverage. Or you can use plyers like these to wrestle it out http://www.harborfreight.com/cpi/cta...emnumber=38496 A touch of heat on the crank can help too.
And yes, I suspect you are describing the normal smell of a ell-used crank case. The tranny is even better...
UAE Rennlist Ambassador
The two balance shaft keys are moon shaped so the taping one end method works, however the crank one is not cupped on the bottom, it is just a rectangle with rounded edges, so tapping one side will only push it into the slot harder. Just use a set of end cutting pliers and grip and pry it out like earlier stated.
Rocket Scientist
No problem. I can't seem to remember a smell, so it probably wasn't obvious. But that doesn't mean it wasn't there anytime I pulled a pan. You might just be a little more over sensitive. Are you removing the pan for an oil pan leak? Might as well change out the rod bearings while you're in there. They're not that expensive, make sure to buy new nuts as well, and having fresh rod bearings never hurt anyone. And having fresh nuts is preferred so I've heard.
No
I have the motor down to a bare block. I got the key out with a set of side snips.
Another odd think that that there is travel forward to back on both balance shafts. They are still bolted to the motor but I did notice that there was a lot of travel.
