what needs to happen for the condenser to come out?
I need to chnage the condensor because it leaks but I can't find any instructions on how to remove it. Is it easy... hard?
I've done it on an N/A and you need a couple of crescent wrenches to disconnect the A/C line fittings, but you could probably get by with regular open end wrenches. Loosen the support brackets and it drops right out.
Same on turbo, just hold nuts on unit w/ open end wrench so not to twiat metal, and rops right out. Unluckly for me my air splitter was ripped off from tire tread, so it was that easy, before I had the splitter bolted in such a fasion that the bumper would have had to come off, so I caught a break.
Steve
Steve
Sounds like an easy job then. Has anyone used the condensors from www.griffiths.com? they are significantly cheaper than OEM ones and claim to be much better.
Cheers.
Cheers.
