What do you wrap your balls with?
I have removed the factory brake shield from my front brakes. I have been using thermal sleeve to wrap the ball joint and tie rod ends to protect the rubber boots from the heat of the rotor. I did some searching around and have not found a commercial product that addressed this problem.
I was wondering if anyone has a better solution.
Thanks Doug, I been sewing the sleeve together with stranded wire. Sounds like you are wrapping wire around the entire sleave, Ill try that.
Why did I remove them?I added brake ducts and the stock brake shield rubs big red brakes.
i was just thinking of this since i removed my heat shields and put in my lindsey brake duct kit. I may just cut up a set of old heat shields i have and bolt just the lower portion of the original back on.
