Attention 951 track junkies...need some help setting up my dash
Alright guys, I have a mychron xg log (pulled oem cluster) that I am using and I am about to set up led alarms on the following:
-boost
-oil pressure
-water temp
what do you guys think I should set the alarms for, also my motor is stock with k26/6:
-boost
I have it set at 15psi (is this too high for track work)
-oil pressure
what should I set for low alarm and high alarm, really trying to avoid spinning a bearing due to low oil pressure
-water temp
currently set min at 160 and high at 220
lastly, what should I set my shift light for? I currently have it at starting at 5000 and blinking at 5800
thanks
-boost
-oil pressure
-water temp
-boost
-oil pressure
-water temp
thanks
Is it possible to switch the boost alarm for oil temperature? I would use an external boost gauge to monitor boost, since for the most part, once you get it dialed in, any decent boost controller should keep the boost pretty consistent. You oil temp, on the other hand, will fluctuate andis something you should keep an eye one.
I might put in a channel down the road to monitor oil temp, but I like the idea of a boost alarm because I already had one mbc go bad with significant boost creep...
However, can't we roughly extrapolate oil temp by monitoring water temp??
I would keep your boost at about 12-14 psi if youre running the stock K26 on the track, just to avoid blowing your turbo.. I didn't pay attention before one run, and my boost was set at 19 psi on stock turbo. Luckily it just blew off an intake tube and not my turbo lol.
but, here is a pic of my dash....
Attachment 376939
...speedhut revolution gauges. Very nice gauges, are built before shipped (not kept in stock). Integrated shift/warning LED lights. All electric. A little pricey though. GT racing fiberglass race dash. Sorry for bad pic quality, this was taken with my iPhone lol.
Also, I am in the process of hooking these gauges up right now, and need to know where to set my water temp and oil pressure should be set as well.
-Happy motoring
Attachment 376939
-Happy motoring
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
On the other settings I would lower the coolant temp to 210. Remember that its a warning light - you want it to come on so you will take a closer look and monitor the situation. You can still run at 210 but you should know that the temp is going up and keep an eye on it.
Oil pressure - I would set it at 2bar/30 psi. If you drop to that level when on the track (rpms are up) you have an issue. It may trigger when at idle but thats not a problem - if it triggers at 4-6k rpm then you will want to check it out.
RPM - teh stock set up is fine to run to 6500, bu tif you have a stock turbo then there is not much to gain. Again - as with the other warning lights, set it to warn you that the limits is comming- not the the limit is here!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The problem is that it will start to raise the intake temps due to running outside of its efficiency band. 15psi is about the max I would suggest for track use - and a little lower on hot days...
Attachment 376939
-Happy motoring![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Attachment 376939
-Happy motoring
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
the OP car now has a huge turbo on it and the boost is run a bit higher not to mention a different owner.
Anyway welcome aboard
