Exhaust leak?
Official Rennlist
Borat Impersonator
Borat Impersonator
Exhaust leak?
How do you find exhaust leaks?
I think I have an exhaust leak, when I got on the boost I can smell exhaust coming into the car.
The hatch seal is fine, hatch itself is not seperated.
Also when I roll down the drivers side window 1/4 of the way I can smell the exhaust.
My headers look good and there is not black sooty marks around them.
Any tips?
Any tips?
Start the car, then carefully hold your hands around any joints you think may have a leak. If you're quick enough you might feel it before it gets too hot that you can't hold your hand there anymore. That's how I found out my header -> crossover connection was .
1 Post
Here's a post from a few years back:
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/125461-tips-on-diagnosing-exhaust-leaks.html
I had very similar symptoms. I finally identified the leak in my system at the headers down pipe to wastegate link.
I eventually had the whole exhaust redone from the crossover on to the back
WooHoo! POST 1000! I'm a postwhore!
Sort of random, but do you still have your rear seatbelts in? I took mine out and left the bolts out and went driving once and realized that the bolt holes have no cover underneath them and go straight through to the torque tube/exhaust tunel. The car didn't smell very nice until I put the bolts back in place.
Winter44 (10-28-2020)
Official Rennlist
Borat Impersonator
Borat Impersonator
I removed them when I replaced my interior, and haven't put them back in.
I will do that asap. Thanks!!
Wax On, Wax Off
One thing that MPD taught me was when the engine is COLD, spray down the exhaust system with soapy water. and then start the car. bubbles will appear! this works, it helped me find my #2 cylinder and header->crossover leak. However, it doesn't smell good... at all.
Also look for black soot that happens to be near a junction. You usually end up with black carbon around a leak. My #1 exhaust header runner was leaking, and looking at the 4 tubes where they attach to the head, it was also the only one with black soot around it. Under the car, you'd see the soot around the flanges where each piece of exhaust bolts together, if you have a leak. My wastegate output to cat input donut was leaking, causing the whole flange to be blackened.
stuffing a rag or towel in the muffler tip will usually create enuff additional pressure to make it obvious where it's leaking. check all the connection flanges, it's usually there.
