Pulled the head today
Do I get the impression that the trend to use MLS h/g's is swinging back to using stock around here?
Hi David, Glad to hear that there is no damage to the block. A headgasket failure after 50K miles on a modified engine isn't terribly bad.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I will only use MLS on a known flat surface (either fresh machined or thoroughly checked old surface).BTW – it looks like you are running pretty rich (most likely the boost leak!))
We have a couple of tricks we use around here to keep the MLS gaskets from weeping.We use MLS gaskets on just about every motor we build here.From BMW's to Toyota's, the MLS have worked very well. And for trick of the trade..........We use a small amount of silicone around the water jackets before we install the head gasket.If you do this,the MLS wont leak externally or internally unless ofcourse your head lifts.
I figured I would add to this a little since I dont want to see a bunch of guys going out and putting massive goop on thier heads and then they dont seal.We us a light coating on certain applications,other applications will have the gaskets put on dry.
