1000hp car breaks a record and it's a Porsche
Old 03-11-2008, 05:02 AM
lart951
Basic Sponsor
lart951's Avatar
Default 1000hp car breaks a record and it's a Porsche
A record breaking 928 fitted with a nos system and a extimated output of 1000hp, broke a record as the slowest car ever with a V8 engine and Naws.
here is the drivers account
Originally Posted by BRETT AINLEY
Hi All
OK....here is what went on at the Pod...
After a couple of teething problems with my piping, where a Nitrous pipe released at 950 psi and I managed to lose the contents of both my 15 lb bottles rather rapidly lol...
I then set it all up again and having refilled with another 30 lbs , I turned on my twin bottle heaters and once pressure was back up at 950 psi , I headed for the fire up lane...
I then got to staging....I rolled it through the water for a rolling burnout under Nitrous power
I shot a long way past the tree ..lol and had to reverse back to stage in the cloud of smoke that I had created...
I then staged and waited for the green....
Green hit the light and I hit the loud pedal....
That when it got really funny lol....
I have no LSD and so I had so much power that my rear left started spinning....
And kept spinning as I headed up the track......1/4 track...STILL SPINNING..
Half track.....STILL SPINNING
3/4 track......STILL SPINNING
Full track....STILL SPINNING
Time was a 17.46 at 94.87 mph.....lol
I have NEVER felt so much power in a street car and obviously my car/Nitrous system is designed for high speed runs....not drag racing...and all I did for the whole run was keep pulling the wheel to the left to try and keep it straight
I did see 7500 revs on the tacho at one stage although I did melt a plug as I went through the timing light at the top end...
The plug gone meant my day was finished (why is it always the LAST one you change out of 8 thats the bad one lol)
I will add 3 pictures of the melted plug...
In total it was a great and relaxing day, got a lot of setting up done and will now move to NGK B9ECS (retracted nose plugs and 2 more heat ranges colder) to save melting any more, I will also alter the fuel/Nitrous ratio to a safer level, lol...
All the best Brett
one thing for sure it can't be any slower.
check the beast
Old 03-11-2008, 06:27 AM
Ian Carr
That Guy
Ian Carr's Avatar
SIICCKKKK
Old 03-11-2008, 08:15 AM
Spidey944
Spidey944's Avatar
I think... no wait... I definitely, just threw up a little in my mouth.
Old 03-11-2008, 08:24 AM
PorscheDude1
On the Radar
PorscheDude1's Avatar
Slower than a yugo!
Old 03-11-2008, 08:31 AM
hpfiend
hpfiend's Avatar
I hope it was tuned for 950 psi as that sounds sort of on the low side for bottle pressure-
Also- that mph doesn't make sense with that much wheelspin it should be higher when it hooked up at the end of the track.
Old 03-11-2008, 09:07 AM
xsboost90
xsboost90's Avatar
i ran an 18 flat in my 2.5l four cylinder chevy s10 back about 12 years ago. No naws.
Old 03-11-2008, 09:41 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Pretty beefy bottle bracket.....bolted to the back of the folding seat...!
Old 03-11-2008, 09:50 AM
Tms951
Tms951's Avatar
What a joke, 94mph? I have run a 14 flat@97mph in a 180whp car.
Old 03-11-2008, 09:54 AM
Opeth
Opeth's Avatar
Is this a joke, lart this whole post is nauseating.
Old 03-11-2008, 10:01 AM
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
nope its all true......just go to the 928 forum the guy obviously had no traction.
Old 03-11-2008, 10:05 AM
reno808
reno808's Avatar
bbbbbbbbhhhhhhhaaaaaaaaaahhhhhhhhaaaaaa good find lartiga. Its so sloppy in there
Old 03-11-2008, 10:07 AM
Fishey
Fishey's Avatar
928 owners are doing it wrong... thats all there is to that..
I don't understand the nozzles how is he getting atomization at all with that setup?
Old 03-11-2008, 11:55 AM
IPSC
IPSC's Avatar
That is the icing on this cake...
IPSC
Old 03-11-2008, 04:05 PM
CarbonRevo
CarbonRevo's Avatar
Dang, that's only about 1.5 seconds faster then my friends 1.6L 4 door civic.
Then again, my friend ran a 19.2 because his car popped out of first when he took, causing him to put it in 2nd at about 2500 revs and go from there.
So in all...my buddies civic is probably faster! LMAO!
It has 106hp/ 103tq!
Old 03-11-2008, 04:21 PM
Kool
Part of the IN Crowd
Kool's Avatar
That is all
Quick Reply: 1000hp car breaks a record and it's a Porsche
