CREAK RATTLE NOISE FROM REAR HATCH
As you can see in the picture I have an adjustable rear wing and I have a constant rattle from rear hatch over hard bumps. I have tried to adjust both hatch pins & lube locks. Still there and it drives me bonkers since I can't stand rattles any where
from the car. There is all the correct foam and padding around to seal properly.
Any one had this before or have any technical suggestions?
Thanks in advance for you input!
That could be possible though it has 34K on the body? It sounds like the pins that lock the hatch to the rear locks have play but adjusting the pins did not solve the issue. The sound is mainly from the right rear area and happens during harder bumps. Suspension set up doesn't help being so stiff so may be I should live with
it!
it!
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Now if only the made viagra for weather seals? LOL
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
I have the same problem with my car and i can see the glass and the frame spread apart when i open it. I am assuming that you have the same problem. Nice wheels i have the same ones for my car.
