Home made Eruo fog lights. Cheap mod.
#46
Not Special
I too did this mod, worked out great. I actually finally got around to hooking up the driving lights this past weekend. I used a spare foglight switch to keep things looking factory and ran seperate wires for the driving light circuit activated by a relay so 100w bulbs will be no problem. Check out this thread here for wiring instructions (i will post an update shortly with the correct wiring diagram).
https://rennlist.com/forums/944-turb...g-harness.html
#47
Geaux Tigers!
Thanks I appreicate that. Sometime ago I read that thread a couple of times but that was apparently before you updated it. Now to source afoglight switch.
BTW, hope you don't mind but I may copy you on the yellow Lamin-X. My passenger side has some pitting that I hope the Lamin-X will disguise.
#49
+1 for the yellow fogs and euro conversion. I purchased my film as a kit for the 944 turbo from Xpel and custom cut the covering for the foglight trim pieces from the extra film in the kit. I have also removed all the amber color from the car which really helps them stand out.
The other good thing about the film is it should provide at least some impact proctection and help cut down on the sandblasting these things seem to suffer from.
