Home made Eruo fog lights. Cheap mod.
#33
I'm still a little confused re: wiring. So my plan is to simply have the second fog light (AKA "driving light") running simultaneously as the fogs. Can I merely tap into the low-beam flip-up lights?
Also, if I'm running 55W H4s would I still be OK adding this extra fog light?
BTW thanks for the idea!
#34
#36
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/400504-euro-driving-lights-fogs-with-iceshark-s-lighting-harness.html
#37
Completed the 'conversion' in about an hour. Salvaged the lenses out of a set of shattered fog lights. The only major short coming of using a spare fog light reflector is aiming them is a bit more difficult. Still possible, but will require removing the light to make adjustments. If you can find the reflector from a damaged driving light, you would basically have the exact same functionality as a new OEM euro driving light.
#38
Basic Sponsor
I found a set of broken fog lights on ebay no affiliation, good for a euro convrsion
http://cgi.ebay.com/ebaymotors/ws/eB...MESE:IT&ih=014
#40
Basic Sponsor
When people say that I need to put larger wire in my wiring harness for the driving lights, does that meanthis wiring harness:
Or all the wires from the fogs to the relays/fuses?
I want the driving lights to be on when the fogs are on reguardless of the headlights and brights. How should I wire this?
#43
I would use the fog light switch to activate a 5 pin relay, then use one power terminal from the relay to power the driving light and one to power the fog light - only need to use thicker wire from the relay to the bulb
also I still have 1 good fog light for anyone that wants to do this conversion
#44
Geaux Tigers!
I know that this an old post but it's one that I parked in the back of my head for a "to do." Took about 30 minutes to fit the extra reflectors in today. I'm ordering Paragon's driving light kit to wire them in unless Travis has a provision on his light wiring kit.
I haven't seen you around lately JE but if you somehow find this post thank you.
#45
I too did this mod, worked out great. I actually finally got around to hooking up the driving lights this past weekend. I used a spare foglight switch to keep things looking factory and ran seperate wires for the driving light circuit activated by a relay so 100w bulbs will be no problem. Check out this thread here for wiring instructions (i will post an update shortly with the correct wiring diagram).
https://rennlist.com/forums/944-turb...g-harness.html
