Post up your projects guys
i tend to run into these vented nosepans alot for some reason. I have a turbo nose in the garage right now and a wrecked ventednose that im using to build another turbo version w/ the 924t vents for a rennlister. THe ones on the red car came from Tifosman and the ones on the grey car i cut from a nosepan that another rennlister had. Ive had about five of these nosepans so far- oh make that six my brother in "law" has one on his car now too.
PM sent.
hey Ben so its running? or did Sam steal all your parts?
Ben, are you running your car without the bolt that holds the fuel rail to the cam tower?
We'll post results in a few weeks.
sweet looking motor George. Did you have any issues w/ the hood closing w/ the hose for your catch can mounted there? i ran Sam's like that and the hood was pinching the hose- i had to move it over the strut tower.
Body work's done
Now onto goodies
garrett gt3076r , stealth maf, piggyback, 83lbs injectors, plx r-800, wideband 02, LR 3" exhaust, 3" downtube, borla xr-1, kw v3, lr stage 1 intercooler
and refinish and powdercoated black chrome
Now onto goodies
I am installing a Haltech EMS unit that I bought used from Jason Judd, along with fixing an oil leak that was there since the engine rebuild I did 2 years ago. I'll be using the stock turbo & injectors for now, curious how the car will do with a 26/8 and the Haltech. My real goal is reliability though, since my factory wiring harness was giving me all sorts of problems.
Here is my list of parts for the EMS:
EMS + Harness
Intake Air Temp Sensor
Intake Air Temp Sensor Bung
Coolant Temp Sensor (small thread)
S3 Crank Sensor
Crank Sensor Connector
Rare Earth Magnets
Dual Channel Ignitor
2 Coils
Plug Wires
Idle Control Valve
Idle control connector
Shift Light
K&N Air Filter
Haltech Trim Module
Boost Control Solenoid
Electric Oil Temp Sensor
Boost Gauge (to replace Autometer gauge that has gone bad)
EGT Monitor - 4 channel
EGT Bungs - Compression Fitting
Adjustable Timing Gear
Innovate LC-1
Parts for Maintenance:
MLS Headgasket
Intake Gaskets
Coolant Gaskets
Oil Cooler Seal Kit
Cam Tower Gasket
Cam Woodruff Gear
Oil Thermostat
Oil Thermostat Sealing Ring
Coolant Thermostat + Circlip
Steam Vent Kit
Taps, Tap Handles, Drills
Wastegate Doughnut seal
Sunroof Gears
Timing Belt
Balance Belt
Lifters (2)
Hood Shocks
Sorry no pictures yet, but they'll come.
Edit: Here is my harness layout
EMS + Harness
S3 Crank Sensor
Rare Earth Magnets
2 Coils
Plug Wires
Idle Control Valve
Shift Light
K&N Air Filter
Haltech Trim Module
Innovate LC-1
MLS Headgasket
Intake Gaskets
Coolant Gaskets
Oil Cooler Seal Kit
Cam Tower Gasket
Cam Woodruff Gear
Oil Thermostat
Steam Vent Kit
Sunroof Gears
Timing Belt
Balance Belt
Lifters (2)
Hood Shocks
