I hope it snows tomorrow........
Old 02-22-2008, 07:31 AM
  #31
reno808
reno808's Avatar
Originally Posted by DDP
Might want to ask Dave again about what else will be required to make 400whp with boost at that rpm. You'll need more then a turbo. If you're just changing the turbo and installing MAF, MBC etc. You're best to shoot for a lower number, I don't want you to be disappointed, lol.
I hope this answers your question
Originally Posted by reno808
everything is going to be replaced/modded besides the pistons/piston rings/rods and the cyclinder walls will remain stock.
Originally Posted by Chris White
400 rwhp is not unachievable with a stock 2.5. I have done that with no internal mods before, it did take a lot of bolt on parts and standalone!
1 bar at 2800….piece of cake, all my set ups can run at 1 bar absolute even when the engine isn’t running…..
we will see what happens
Old 02-22-2008, 11:11 AM
  #32
2bridges
2bridges's Avatar
Old 02-22-2008, 12:05 PM
  #33
toddk911
Drive-by provocation guy
toddk911's Avatar
There ya go!
From the engine/internals point of view you can't get much better of an expert endorsement than from Chris.
Of course some head work would make the task much easier. But I think the secret will be in the turbo choice. There have been plenty of people in here that run 20psi on pump and never any problems on the street. Track??? not so sure that much on pump.
But the right turbo, 20psi (give or take) solid motor with maybe some internals worked, especially the head, and you should be ok. Especially after Chris' statements you should be much more convinced you can pull it off.
Old 02-22-2008, 03:58 PM
  #34
DDP
Rocket Scientist
DDP's Avatar
[QUOTE=toddk911;5135112]Of course some head work would make the task much easier.[QUOTE]
No, it will make it possible. And only with a cam as well.
Sorry Reno, I missed the post where you said you'll change everything but the shortblock.
But I'm still doubting the 1 Bar by 2800 RPM unless you're running an excessive amount of boost on an excessively expensive turbo with an excessive amount of fabrication to fit.
Old 02-22-2008, 04:22 PM
  #35
adrian1
adrian1's Avatar
This maybe a little of topic but; toddk911, How do you like the super 75 turbo? I am looking to purchase that one but have second thoughts about the lag i keep hearing about. I will be using it with a 2.7. When do yo reach 1 bar?
Old 02-22-2008, 04:35 PM
  #36
toddk911
toddk911's Avatar
With the 2.5, exhaust header leak and some fine tuning that could happen, I get 1 bar about 3,800-3,900. I think most of that lag is the leak, as once the turbo is flowing and velocity built, it spools very fast.
i.e. 0-10 psi is slow, but 10-20psi is FAST.
I think George D is using the 75 on his 2.7/3.0 and was seeing much quicker spool.
With no leaks, dead on tuning, I have been told I could see 1 bar about 400-500 rpm sooner, best case scenario.
So with no leaks, good tuning, etc. and the 2.7, I would say you could get 1 bar by 3,200-3,300. But this turbo also can easily run 20+psi to redline and past and still make power and not just more heat.
But so you know, this really is a "top end" turbo for someone that is more about full power to redline and not tapping the pedal and the tires spinning. If you want to spin tires in 3rd at 4K rpm, then this is not your turbo.
But I feel that when you hit the gas and are always spinning tires (full boost at 2,200rpm) or have to be in a straight line when you hit the gas then that is not usable power either; not all that streetable.
My dyno showed a VERY linear roll on of the power; Like an NA car. Not the instant tq of an NA car, but still holding almost full tq to about 5K with stock internals, cam and valve train.
Old 02-22-2008, 04:39 PM
  #37
adrian1
adrian1's Avatar
Yours isn't the new TBB 75 is it?
Old 02-22-2008, 04:43 PM
  #38
toddk911
toddk911's Avatar
No. Mine is NON bb
Old 02-22-2008, 04:48 PM
  #39
adrian1
adrian1's Avatar
Thanks for the info!
Old 02-23-2008, 10:39 AM
  #40
reno808
reno808's Avatar
Dam forgot to put on a car cover on the 67 and the 951
Old 02-23-2008, 10:41 AM
  #41
evil 944t
evil 944t's Avatar
Don't you have a "Special" friend with a plow? Get that engine out!! ps - Get that "tool" send the BMW pan!
Old 02-23-2008, 11:09 AM
  #42
2bridges
2bridges's Avatar
wtf reno - you got tires and **** leaning up against your car??? no comprede, mas cervesa muy beuno chimichanga
Old 02-23-2008, 12:30 PM
  #43
reno808
reno808's Avatar
Yeah Special Friend is home reading the manual on how to operate the plow and sipping some tea cus he doesnt feel too good. Dude the pan has been sitting on the bench for over a month now lol
Old 02-23-2008, 12:36 PM
  #44
reno808
reno808's Avatar
hahaha the reason why i have those tires there is because the dam car cover keeps blowing AWAY
Quick Reply: I hope it snows tomorrow........
