proper brakes eh :)
330x28mm with 61mm width rotors, full floating direct drive by PFC, gonna start makeing hub adapter and caliper adapter, gonna run PFC97 pads. I have also bought rear calipers to get the weight down.
beats useing stoneage 993 biturbo stuff, should outbrake it easy, and weighing a few kg's less![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
also started on the ruff sketch of the caliper adapter.
has anyone got technical drawings of the old 944Turbo rotors/calipers and perhaps 996?
![](http://anders.fqdn.no/albums/944/996caliper944rund.sized.png)
![](http://anders.fqdn.no/albums/944/DSC00517.sized.jpg)
![](http://anders.fqdn.no/albums/944/DSC00518.sized.jpg)
![](http://anders.fqdn.no/albums/944/DSC00519.sized.jpg)
![](http://anders.fqdn.no/albums/944/DSC00520.sized.jpg)
![](http://anders.fqdn.no/albums/944/DSC00521.sized.jpg)
What caliper will you use? Or the ones in the picture? Because they look like 993TT stuff.
Looks good Anders. I'm a fan of PFC and was pursuing some of their stuff in the past. I'll be watching this thread to see how you go.
again, if anyone has technical drawings on anything it would be awsome, much easier as I don't have to measure anything then.
your brakes and tires will go further will go further than those on a 993 but but you will not out brake a 993 due to its rear wieght ballis .
think about how you best stop your bicyle with your ***** rubbing the rear tire
What about showing the adapters that work with the late model offsets though Olli?![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Anders, so by going a slightly thinner disc does that have any effect on the pads re not using the PFC calipers? Are you going to leave your master cylinder stock?
Sure we have some inherent disadvantages against a rear engined car so there's no changing that, but we also have some advantages. No point not having major stopping power if you have major power.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
