Evolution motorsports diverter valve spring rate
I believe my evo diverter valve is opening too soon. I can here a boost leak in that area under boost. I'm also seeing late spool up from my stock k26, where should it see full boost (14psi)? Also when I shift and I hear the diverter valve the car goes rich (low 10s) for a moment, would this be caused by my valve?
Lindsey sells a stiffer spring for $10
http://www.lindseyracing.com/mm5/mer...de=BYPASSVALVE
or what looks like the better deal,
forge motorsport 4 different springs for $15
http://www.forgemotorsport.com/conte...roduct=FMDVTUN
Your right the stock spring is weak.
As for the two options above, I have both forge spring kit and the Lindsey stiff spring. I have not had a chance to try either of them yet. The Lindsey spring is longer and "feels" the equivalent of the blue spring in the Forge kit.
I am going to try the Forge spring first when I get everything back together and to the Dyno here in the next couple of weeks.
Either option is better than what is in the EVO valve stock. Also I would suggest regreasing the O rings in the valve with a thick grease from time to time as well.
IPSC
IPSC
BUMP
IPSC, Keith, others
Which spring in the forge kit was the "right" one for you?
I read the next thread in my search and found this:
IPSC, Keith, others
It comes with five springs of different stiffness and some light weight aluminum shims. The springs are the same diameter and height as the EVO BOV. Right now I'm using the yellow spring, middle of the road, it is stiffer than the EVO spring and the BOV no longer bleeds off early. The red spring seems really stiff, so I'm staying away from it for the moment.
Mine goes rich when I lift the throttle too... even if there's no boost..
But I'm not blaming that on the DV. My problem is the flutter.. The spring kit is fairly inexpensive (not that I think 4 springs cost very much) so I want to play with it a bit and see what changes I can make.
"From Forge rep: Mike@Forge"
If you are finding that your valve is dumping more air than required, venting too soon, or it is leaking boost before the redline of your application is reached, it is normally an indication that the valve is adjusted or tuned too softly and that a stronger spring or more spring tension is required. Conversely if the valve is failing to dump boost pressure, or you are experiencing valve fluttering at full boost throttle lift, it may be necessary to install a weaker spring or tune the valve to a softer setting.
For the "rich off throttle" condition you may want to look at the TPS adjustment.
It should cut fuel at anything over ~1600 rpm when the throttle closes. If it is not adjusted properly it will continue to add a little fuel between shifts and on decel.
did you guys have a problem sliding the barbed end into the j-boot or into the rubber hose? I had problems and ripped the j-boot. should i just upgrade to an aluminium inlet tube or pick up another rubber j-boot
The best solution is to go MAF, but it will cost a bit more.
Yes I'm thinking about updating/organizing the body project thread because its basically done. Took a few quick pics the other day just need to find the time to upload and post when I'm not busy.
