wiring harness
my reference sensor connectors are old and cracking, on both sides and having the starting issue where i have to wiggle them to start the car sometimes.
i see lindsey racing has some, is there anyone else that sells the wiring harness?
-BB
alright, i might as well get the fuel injector isv and knock sensor harness's and do it all at the same time, right? is there a replacement harness for the tps sensor?
hopefully its worth the $450 for new wiring !!! and not too much of a pain to replace
I have all of the replacement harnesses Lindsey Racing sells in my car. I did them all at the same time and thermal sleeved everything that was left. The harnesses are top notch and really helped solve some electrical problems I was having.
Ditto here, I have every harness except the new temp/ISV harness. The install is not bad and it solved a rough idle I had. I used a large diameter weedeater string to fish the harness throught the snorkel so everything comes out where the original harnes does. looks better than factory and is excellent quality. I am ordering the harness they just came out with this week.
I really wish someone would build a complete replacement for our cars. As you guys say, these harnesses are getting old. The sleeves get hard and brittle and break and expose the wires, which then get hard and brittle and break as well.
If only someone would build a complete harness, not parts of it. Use all factory connectors everywhere. In other words, something that is an exact factory harness replica.
Raj
Raj
