New Pulleys/Gears
I got the Crank and Cam ones on the last GB
I have the Broadfoot underdrive set for the rest. I was just wondering if they had decided to make the balance shaft gears as well when I saw the first pic!
yes, BS gears are in the complete set. The only thing Jeff hasn't made is the timing gear on the crank. There have been some people who have asked for it so he may make that as well this year, he was undecided the other day.
I just installed my set this past weekend. Jeff even made me a custom accessory crank pulley and spacers for the ps crank and pump pulleys to accomodate the 3mm trigger wheel. Here is a shot of the bs gear and cone washer compared to the stock ones.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
how much would a setup to replace the crank pullies (timing, balance, accessory), cam gear, and balance shaft sprockets, unanodized?
also would it be possible to add an identical accessory pulley to the front of the existing accessory pulley instead of power steering?
