Boost/fuel chart?
Rainman
Well I've made good use of the tire size calculator and the transmission ratio/speed calculator...
anyone have a chart or calculator that can see the minimum octane needed to avoid knock at certain amounts of boost/compression ratio?
That'll be hard to do, 'cause there's more variables that have to be considered, like: temps, timing, camshaft, cylinder size, air/fuel.
You could probably get away with pump 87 octane running 8.5 compression with 16 psi boost, on a cool humid day with moderate ignition timing, clean oil-free intercooler, and long duration camshaft, and 11:1 air/fuel
You'd probably need race gas with the same boost/compression on a hot dry day, with a mild cam, a few more degrees timing, and 12.75:1 air/fuel, running it on the track.
Not much more to it than that.
Rainman
i was greatly warned by my grandfather (worked in petroleum laboratory for 30-40 years) that ethanol would destroy my fuel system. i imagine my injectors would be fine but the rubber lines i am concerned about.
also, any danger to the fuel pump?
Rainman
Things to consider:
stock 944 camshaft
9.5:1 compression
10psi boost (ECR of about 16)
about 70 degrees ambient temperature
clean intercooler
spark retarded 4 degrees
fuel increased 6%
think 91 octane will take it?
stock 944 camshaft
9.5:1 compression
clean intercooler
fuel increased 6%
Rainman
on the last post i changed the number of psi to 10. right now im playing with different levels of boost and seeing which is the maximum i can go given my engine's setup and availability of local fuel. regardless of boost i want to use the highest octane readily available, which around me is 91. i just want to see how much i can crank the boost without knocking.
