Safe to run Methanol inj @ 15PSI?
#31
88BlueTSiQuest;
Lorax is right; he just commented on the fact that the original poster might think the methanol is similar to a nitrous kick, which is far from the truth. If you don't up the boost, the added power from just the little extra charge cooling is minimal.
I haven't come across the perfect WI kit. The snow performance kit is far from being the best. Their pump is good, and their plumbing is good. Their safety system sucks; they don't have proper valves for preventing siphoning and/or that the system is always primmed. This is crucial.
Aquamist doesn't cater to those who want to run higher percentages of methanol; their pump is a bit flimsy. Other than that, everything else is good.
#32
The Impaler
88BlueTSiQuest;
From what I have heard the aquamist nozzles are really high quality too. You could just use those and the aquamist management system with all its little bells and whistles and find your own pump pretty easily.
#33
maybe if the ethanol station were in north county i could do it.
i should replace all my fuel lines soon anyways, any recommendations to something that could handle both regular gas and possibly ethanol?
i have 4 extra CME's so i could just set one up to run the ethanol and swap them depending on my mood...lol
There will be one in North COunty soon.
#34
#35
What makes snowperformace the best? from what I've read It's a very basic set up with little protection against failure.
I have a friend that runs aquamist and it is far superior to anything I've seen on the market. they have some really cool stuff.
http://www.aquamist.co.uk/cp/cp.html
the aquamist also sends out a signal to shut boost down only, "to minimize damage" the snow would shut down boost and timing depending on how you set it up. so really both systems are the same in design. neither has a technical edge on the other system. So I dont see how the aquamist is "far superior to other systems".
#36
No. you're taking it out of proportion. This is just not true. This is NOT methanol.
#37
I understand ethanol is not methanol, but it is still hydroscopic, and will still be detrimental to aluminum and uncoated steel if left to sit. I want all of my stuff to last a long time, with no corrosion issues.
The alcohol has some sort of characteristic that makes it able to absorb into rubber - thats how the rubber gets destroyed. Or so I read.
I have done hours of research on this subject, and spoken to race mechanics about alchy and methanol.
Methanol is indeed much worse. So much that usuallly its a good idea to run the engine on gas after EVERY methanol use so as to not let corrosion start.
Ethanol is not nearly as bad, but still has some of the characteristics that make people blanch at methanol.
I made aluminum fuel rails before I knew I was going to use E85 or straight ethanol when able - so I have to coat them. Everything else I can buy tailored to its use. So the rails can be anodized or nickel plated.
The info is out there. Alot of people are against it, politically, and environmentally, and hot-rod-wise, people are against it because "It ate through my tank faster than I could put it in, blew up my engine, made me go blind, made my wife fat, and my kid stupid," and I am not expousing that mentality.
It does require (for long range use) more thought in the fuel system than gas.
#39
#40
agreed, it will eventually degrade aluminum. over a very long time. Not to worry about the aluminum heads as it should be a vapor by then and flow into the chamber. but the rubber hoses should be change at the same intervals as a gas vehicle. So shouldn't be an issue there. Steel gas tanks will get the varnish cleaned out. But steel is just fine for ethanol. Most any fuel pumps are made to resist it. (we're all due to change ours out at this time anyway.) Our Stock fuel rails are Steel with zinc Coating. So.... We're mostly there. Minimal change needed.
It's just that what you have said has been taken WAAAAAAY out of proportion on the internet and needs to be kept in check.
Still, it seems that we both still agree..... ethanol is an awesome fuel.
#41
#42
The snow kit is pretty rugged, I had no problems with it, the aqua mist kit is very much the same, but the pump is not as reliable, they both use map sensor to monitor flow, and the snow kit also had a safeguard that put your car in safe mode if it detected a flow problem. I also had an led panel that showed when it was flowing or if it was not flowing, and fluid level. I had no problems with the kit, but you have to maintain fluid level. In all actuality the system is a very simple system, they are not very different from each other. I just have user experience with the snow kit, with out a lick of problems. I never ran out of fluid while in boost either.
the aqua mist also sends out a signal to shut boost down only, "to minimize damage" the snow would shut down boost and timing depending on how you set it up. so really both systems are the same in design. neither has a technical edge on the other system. So I dont see how the aqua mist is "far superior to other systems".
I'm in the process of designing my own system which will be cheaper and better then anything I've seen. better based on pump quality and a properly sized spray pattern. we'll see what happens.
