Project thought for winter and year 2008
#31
I asked this on the othe thread also but In ignition wise
I am looking for plug wires witch I can custom make for my 16 v project.. I need the plug side to be exactly as on 968 but the wire lenght should be adjustable since will be using those COP-s, and they are installed on top of the cam-cover so stock lenght wires are JUST TO Long and would look ugly on my engine bay.. Of course one option is to buy 4 wires witch are made for 1st cilinder in other word shortest possible..
Coil
![](http://www.034motorsport.com/oscthumb/w/450/h/396/q/95/f/jpg/hash/17f243b485bedb9f84726e87cae43445/src/images/IGN1TTL.jpg)
have any of you seen custom plug-wire kit available..
Markus
Coil
Markus
#32
Happy New Year everyone..
New look for my car![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![](http://eku.3lite.ee/albums/markus/DSC00747_001.sized.jpg)
![](http://eku.3lite.ee/albums/markus/DSC00746.sized.jpg)
![](http://eku.3lite.ee/albums/markus/DSC00744.sized.jpg)
Looks kind a empty, maybe I should shold get some differnet wheels now.. black centre with polished lip would look better..
Markus
New look for my car
Markus
#34
+2 on wheels. Same colour wheels almost always look a bit naff to me. Black/Black look 'race' though.
#36
Markus, I don't have those lights yet. Should be just before X-mas.
ittia, by all means go and see those guys. I have emailed them a few times in English and they don't respond. I had a German friend phone them and they were very keen to send some to me. I showed them the same pics of Corleones car and they said you could adapt them to fit same Xenons apparently so we'll just have to wait and see.
#37
No. PM sent.
#41
Formula One Spin Doctor
Well
I am not going to install custom cage since its illegal for street.. allthough Bolt-cage is somewhat legal..
One other thing I have thought about, and what I have discussed with Corleone is my CR and E85..
Since I was thinking to switch to E85 I thought, maybe it would be wise to put back stock thick headgasket (1.3mm) and run 11:1 CR with E85.. + change the hotside from 0.82 to 1,06.
With stock thick headgasket I could use the full benefit of squish + we all know that with ethanol is very crucial if it detonates, stock headgasket will elimante that risk what I had with thinker headgasket and fu**ed up squish area.
1,06 Ar again will allow me to make more power with less boost.. Since I am going to run 11:1 CR then its no problem to make it spool on low-rpm + I can run less boost, less EGT and way more igniton advance (more=5-7 degrees on load). Aim is to have around same power (500-550RWHP) with 1-1.2 bar boost. It could be that the stock exhaust manny is on the way to make that high power on that low boost..
Markus
Markus
More
how much people here in the forum knows about Splitfire? I was thinking to adapt one of their kits witch is originally made for SR20DET engine to my own project. I just have to measure coil lenght, diamter that it can be fitted to our cars.. the set is somewhat 500 USD and comes with everything....allmost..
![](http://www.splitfire-japan.com/images/DI_SR_model.jpg)
![](http://www.splitfire-japan.com/images/DI_SR2.jpg)
![](http://www.splitfire-japan.com/images/di_graph_sr_E.gif)
Copy..
Genuine coil packs used for NISSAN SR20DET were not satisfactory to provide enough energy because of the design restriction.
"SplitFire Super Direct Ignition System" can provide 150% of electricity to spark plug compared to the genuine coil at all RPM by the modified structure of coils. It also improves power, torque and combustion efficiency by complete combustion.
The special circuit adopted for this unit helps to start engine at lower voltage. It provides the excellent starting performance even at lower voltage. It also eliminates noise and RFI (Radio Frequency Interference) for audio equipment because plug wires were eliminated. By conducting radical research and development of ignition system of the SR engine, SplitFire Super Direct Ignition System enabled to improve the performance of engines of not only normal cars but also hard tuned cars.
For responding customers' eagerness, we added SplitFire Direct Ignition System for NISSAN SILVIA CA Engine in our lineup.
Basic Component Parts
Ignition coil/ Control Case/ Main Harness/ Sub Harness/ set of screw and spacer
Copy..
#42
Please correct me if I'm wrong, but I think he's referring to combined effect of E85 and lower boost rather than just higher CR... from what i understand, you can generally run more advance with E85 and achieve similar power with less boost due to the oxygen content of the ethanol in E85, of course you need more fuel though so you haev to look at injector and fuel pumop sizing as well as making sure the rest of your fuel system is compatible with E85.
#43
Dear All
Its been a great being with you all, discussing different matters regarding our awsome cars etc. I have to admit that I have decided to go the route of downgrading my car into stock (well allmost stock). So all the project thouhgts I had for 2008 regarign E85 and other issues are terminated.
Shortly my project thoughts for 2008 will remani
Black leather interiour from 968
Mattblack 18" techart wheels'
Iinstall Stock KLR/DME + chips, Loom
Rebuild 2.5 liter stock engine..
Install stock but 2.5 liter 8 valve engine with 3" Lindsey SS exhaust
Remove stickers from the car (done)
Polish the paint
Tint windows little darker..
Install stock Suspension
![](http://eku.3lite.ee/albums/2007/P1180044.sized.jpg)
![](http://eku.3lite.ee/albums/2007/P1180042.sized.jpg)
![](http://eku.3lite.ee/albums/2007/P1180035.sized.jpg)
Car is also for sale if someone is interested..
Polish the paint
#44
What's happening Markus???
#45
I suppose Markus will be soon "Down Under". At least he's selling all his cars. A friend of mine is going to buy Markus' parts car. we are going over next week to pick it up
![](http://i5.photobucket.com/albums/y170/olli951/0004_G.jpg)
![](http://i5.photobucket.com/albums/y170/olli951/0002_G.jpg)
