Another lifter test post.
After reading lifter posts back to '01 I've been soaking + attempting to pump up two sets of lifters. I only need to yield 1 set out of all so this maybe an overkill....but I had them sittting around so what the hell. Anywho after two days of soaking and a half a dozen pump ups I have:
set 1) 3 hard/5 soft
set 2) 6 hard/2 soft
There hasn't been much change since soaking/pumping them in fresh oil. How much longer should I put off reassembly (I'd prefer to keep set 2 together as it was the set pulled from my cam tower) or just combine the hard ones out of the two sets?
Also,I just want to make sure that when people say a "hard" lifter they mean they can not pump it by hand (even using a T handled allen wrench you can't get the button to move). I just don't want to put a lifter in that may be siezed.
I thought that with the lifters soaking in oil, you should be able to press the button down a bit and it will come back up, and that lifter is good. I have run across many lifters that you cannot even move (budge) the button. Stuck as can be.
On my "bad" lifters the little button could be pushed in with my thumb and they would come back dry. The "good" lifters I could not budge with my thumb wet or dry. I had 3 bad from my set of 8. I replaced the 3 soft lifters with "good" lifters from another car.
The reason I looked at the lifters is I was hearing lifter clatter after the motor warmed up AND was getting a power plateau at around 5500 rpm at over 17psi of boost from the floating lifters. Since replacing the 3 soft lifters I have not had a problem so I assume from that experience replacing lifters in a set is okay.
Apprciate any advise you can give..
Dennis
Very hard at the very least, but truly next to impossible, seems to be a better description. After going through 10 lifters I finally found one that would be classified as "NO GOOD". It's very obvious when a lifter is really gone, with much effort it actually compresses almost flush with the bottom of the lifter and has a pronounced click as you release it back into position. I was really surprised...at first at thought I was chasing some lifter testing myth. One side effect is my thumb is numb from pushing on lifters all afternoon. Definitely worth it if I can eliminate that noisy lifter racket.
